Question about JVC AV-48WP30 48" Rear Projection Television
Oil low in red lamp
The oil in the red lamp is low what do i do about it.
  • Ego1 Nov 26, 2007
    i drained mine and by accident it didnt damage anything but it did make a mess, i didnt even know they had oil
  • Anonymous Dec 11, 2007
    low oil
    Scholar:
  • 87 Answers
The substance is a clear antifreeze. The purpose is to keep the phosphors on the CRT cool so it wont burn. If the liquid was low, it means there is a seal or bladder leak somewhere. The tube needs to be removed and the leak can be patched with silicone rubber or the blader needs replacing.( check for cracks). Refill with coolant and re install. Use rubber gloves because the liquid coolant is hazardous to your health.
Posted on Dec 12, 2007
A small red alladin lamp type symbol with 3 droplets coming from the spout. what is it? what does it mean?
Look in your manual instrument cluster section. You did not specify the year, make or model to determine what it means. If you do not have the manual, google search year, make, model and manual.
You might want to check your fluid levels right now, as red light on dash is not good.
Mar 09, 2015 | Cars & Trucks
Where is the oil pump situated on a CateraS 2001.Have low oil pressure when idling or at a red light.
Hi Rejean, I suggest you have the oil pressure sender unit inspected before thinking of replacing the oil pump. If it's the sender unit the job will be a fraction of the cost of an oil pump replacement, which means opening the engine. Regards John
Jun 22, 2014 | Cars & Trucks
Why red oil light flashed just once while hard braking
HI,LOTS OF CARS HAVE ,A WARNING WIRE ,FITTED TO THE BRAKE PADS,WHEN THIS SHORTS OUT ON BRAKE DISC,IT PUTS THAT LIGHT ON,SO CHECK BRAKE PADS ALL ROUND,ALSO BRAKE FLUID CONTAINER HAS SAME WARNING LAMP,CHECK FOR LOW FLUID,THANKS.
Jun 01, 2014 | Vehicle Parts & Accessories
Why does red oil aladdin lamp shaped light appears in Toyota corolla
It is indicating you have a low oil level in the engine.
Aug 23, 2012 | Cars & Trucks
Red oil light appears
WARNING! THis could be some problme of OIL LEVEL LOW, check it and refill if is necesary. Keep running your engine in this condition could damage other components or engine itself.
If the oil level is OK, then could be some problem with the oil sending unit or oil pump.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 23, 2012 | Toyota Cars & Trucks
1999 Eldorodo etc. Only when it is hot outside (over 75 degrees) and idleing in drive does the red oil lamp in the dash light up. I am using 10w30 oil.
The oil lamp indicates low oil.If you have checked the oil several times and it is fine,the sensor may be failing,or there is a loose connection in the system.When cars start aging,you should use a slightly thicker oil too.10W-40 is fine.I have a 1995 which suggests 5W-30 and I use 10W-40.Your issue is pretty unusual too.Call your mechanic and ask his opinion too.The 10W-30 switch is nothing urgent though.Just do it at your next oil change.Good luck!
Jul 04, 2010 | 1999 Cadillac Eldorado
PASSAT 1.9TDI 1999 YELLOW LAMP OIL
check your oil level coz when it flashes yellow or orange its a warning that ur low on oil if it turns red dont drive the car untill u get oil in it and ull need fully synthetic oil
Oct 25, 2009 | 1999 Volkswagen Passat
JVC AV-48WP30 48" Rear Projection Television Logo
48 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
