Hello my Goodman WMC24A Split Unit is not working. I had it for 6 yrs with no problems. I turn it on and the fan kicks on but the Condenser unit does not. Does this unit need to be recharged with R22? If so, do I need to call someone to do that?
  • 614 Answers
A few tings to check first. See if there is a float switch located at your inside unit. It may be tripped if so you have a stopped up drain. You can clear this yourself by useing a wet vac out side and **** the restriction from the outside. Check your breaker to the outside unit. May be tripped. Goodman does not have alow pressure control so even if it is low on gas it will run. Try these ywo items and last call a service tech but get free estimate before you commit. RUSS
Posted on Jul 16, 2009
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Goodman air condenser is humming but the fan does not come on
The most likely cause is the fan motor has failed. If it turns free then see if the capacitor is bad. Turn off the power remove the capacitor. Your local supply houses can test it for you.
Feb 15, 2013 | Goodman Manufacturing Goodman GSC130181...
We have a goodman split unit, It was below freezing the other morning and the unit had a squeaking sound when it started up. Now it has warmed back up, the unit is sounding as if it's trying to kick off...
The symptoms seem to be related to the main blower motor and/or it's capacitor. Turn the system off for a couple of minutes and then turn just the fan on while the thermostats heat setting is in the off position. If the lights still dim then replace the motor and capacitor. The clicking noise is the fan relay.
Dec 17, 2010 | Goodman GMS807034ANA Heater
Condenser fan will not turn on, although I can hear the relay click. This is a Goodman 3.5 ton unit about 12 yrs old.
Is the compressor running? If not then check the disconnect or fuses. If it is then make sure the fan turns freely and check the fan capacitor. Replace it if it is bad. If the capacitor is good then check the fan motor windings and replace the fan motor if the winding are open. Let me know what you find.
Jul 26, 2010 | Goodman CKL42AR42 Air Conditioner
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
My goodman cental heat & air unit quit working last night
check to i see if there power to condenser. check to see if there 24 volts to condenser.checkt the disconnect box for power located out side by the condeser you should have 220volts at that box. check to see if your stat is set on cool.
Jun 20, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
