Question about Car Audio & Video
I have a ford explorer 1994 that has the speakers going thru an amplifier, it requires an additional 12 volts on a blue wire that needs to come from the radio when it turns on, how do I get this done with this type of radio?
  • 322 Answers
You need to get a BTL converts your radio into rca jacks so you can control the power of radio and amplifier.
Posted on Jul 17, 2009
Need wiring diagram for 1996 Ford Explorer Sport radio,connecting wire colors, the one I have is different than what's on vehicle
Check this diagram for 1996 Ford Explorer Car Stereo Radio Wiring Diagram...
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Hope this helps; remember to rating this free answer and leave some testimonial comment.
Oct 13, 2011 | 1996 Ford Explorer
I have a 1996 ford explorer we installed a new radio the power works but no sound
Hello my name is Israel and I will try to help. In the set of wires from the vehicle there should be a blue wire that need to be connected. Blue wire should be connected to a switch positive 12 volt. This will turn on the vehicle amplifier. Good Luck.
Mar 22, 2011 | Car Audio & Video
What is the stereo wiring diagram for 1997 ford explorer xlt,and does it have an amplifier?
1997 Ford Explorer Car Stereo Radio Wiring Diagram
and im not sure if it has an amp but it has the triggger wire
pls rate
Aug 16, 2010 | Car Audio & Video
Need to know speaker wire colour config for 1994 4runner (toyota) as well as power and earth wires
A Right Front Speaker (+) Green Gray B Left Front Speaker (+) Pink White C +12 Volt Ignition Wire Gray Red A B C D K L D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow E Right Front Speaker (-) Blue Gray w/ Black Stripe E F G H I J M N O P F Left Front Speaker (-) Purple White w/ Black Stripe G Ground Wire Black Black H Power Antenna Wire 1 Blue (join wires 1 & 2 I Power Antenna Wire 2 together to this blue wire) AS VIEWED FROM MATING END OF CONNECTOR Do Not Use J K Right Rear Speaker (+) Red Purple L Left Rear Speaker (+) Black Green M Right Rear Speaker (-) White Purple w/ Black Stripe Do Not Use N Do Not Use O P Left Rear Speaker (-) Yellow Green w/ Black Stripe
May 29, 2010 | 1994 Toyota 4Runner
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Car Audio & Video
1994 FORD EXPLOER XLT RADIO CONNECTORS HAVE BEEN CUT OFF
here is wire color diagram.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Mar 29, 2009 | 1994 Ford Explorer Limited
Color code for speaker diagram 94 Ford Explorer xlt
Please rate this info.
Right Rear Speaker Negative Wire (-): Black/White
Mar 14, 2009 | 1994 Ford Explorer Limited
I own a 1993 Ford Explorer and my radio just stopped working. I checked all my fuses and they are all fine. What could be the problem
the radio may be defective, pull it out and verify power to the radio, u can buy the radio removal tools at any NAPA parts store or get them from Ford, they are very cheap to buy. here is the wiring colors and what they do, u will also need a cheap 12 volt test light, about $6
1993 Ford Explorer Car Stereo Wiring Diagram
Jan 08, 2009 | 1993 Ford Explorer Limited
Grey cable in dash
Hi again,
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
  • Yellow/light Green - always ON B+12;
  • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
  • Black - chassis/ground;
  • Blue - remote trigger for add-on amplifier (if connected);
  • Blue/Red stripe - illumination (can go to parklight switch).
and the 2nd smaller gray 8pin plug:
  • White/Red Stripe Right Front +
  • Brown right front -
  • Green Left Front +
  • White/Orange Stripe Left Front -
  • Light Blue/Black Stripe Left Rear +
  • Yellow Left Rear -
  • White/Blue Stripe Right Rear +
  • Light Blue Right Rear -
Cheers.
Aug 28, 2008 | 1994 Ford Explorer Limited
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
