Question about HP Computers & Internet
Have HP DV 9540 us laptop. Yhe motherboard took a dump. I can read hard drive on another computer. Can I recover my verisoft passwords for my websites?
  • 585 Answers
Passwords are encryped, the chances are slim to recover except by booting the system on the hard drive and logging in. Boot in safe mode so that windows won't try installing drivers for the host system. If you try to boot in normal it is going to complain, but safe mode should let you in to recover the passwords. If you have the drive connected through USB with adaptor, use the boot options (usually F-12 on recent stuff) to boot from the usb drive.and F-8 before the Windows logo appears to get into safe mode.
Hope this does it for you.
Posted on Jul 17, 2009
  • Bruce Volkers
    Bruce Volkers Jul 20, 2009
    Were you able to retrieve your passwords?
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
When i power on the laptop ask HDD PASSWORD SIR PLZ HOW CAN I REMOVE SIR
How to remove and unlock hard drive password? Is there any software to recover hard drive disk password? Where to download hard drive password cracker? Is it possible to reset the hard drive password?
According to Lenovo and many other manufacturers' website, if you forget your hard drive or hard disk password, there is no possible way to reset your password or recover data in the hard disk drive. Basically the hard drive is unusable. Scary right? However, this is often not true.
Most people are not aware that most hard disk drives have the ability to set a hardware password, just like the Bios password for motherboards, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. Usually these features can only be found in laptops, this is when you set a password on your notebook, the hard drive together with the motherboard becomes locked.
Most experts would say if you forget the original HDD or Bios password, there is no way of restoring it by generic system tools. Unlike the Bios password where there is a master key or with the removal of the bios battery, the password is erased from the flash memory thus the settings is restored to factory settings without the password, however, this does not applies to hard disk.
Jan 21, 2011 | Acer Computers & Internet
Can't remember my password on hp 6000 computer how
Are you talking about the BIOS password, or the windows password?
A hard reset will probably reset your BIOS password (see this thread),
To reset your windows password, you need your XP CD-ROM and follow this instruction.
Jan 02, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Installed an exchanged motherboard on my hp pavillion dv 9081ea laptop. hard drive not getting detected. hard drive has ubuntu 8.04 and windows xp sp3 installed on it
Did you bother to check if the new motherboard was compatabe with your hard drive? Because sometimes, the slots and stuff are, but the motherboard functions differently if the hard drive is not compatable by model. Check again, and maybe, the hdd wasn't put it wright or something.
Anyways, hope this helps.
Jul 14, 2009 | HP Pavilion dv9000z Notebook
Problem with hp laptop dv9000
boot into safe mode and dump that driver and reinstall it or update it... and i can relate to the india customer service thing (there has got to be a better way)..
Jan 08, 2009 | HP Computers & Internet
Drive Lock Password for Hitachi HD in HP Pavilion zv5466ea notebook
probably a little bit late but I think I found a solution ...
1.pull the hard drive out of the laptop
2.boot computer into bios settings
3. set a new bios password and check lock computer
4.while the computer is on slide the HDD in the laptop again.
5. save and exit bios
6.fortunately in the next boot you will get your hdd back
Jul 05, 2008 | Hitachi TravelStar 80GN 80 GB Hard Drive
Do i need a new hard drive
Go HERE and do a search for you computer model. When you find it look under Driver and Software Downloads for a BIOS update. You may be able to recover after updating the BIOS.
Jun 27, 2008 | HP Computers & Internet
Forgot my Verisoft Logon Password
Not sure if you got this sorted, but all i did as i couldn't remember my pasword and could only login using fingerprint
go to
Start
type 'CMD'
Right Click and select run as administrator
In the command window type NET USER XXXXX welcome01
Where XXXXXX is your user Name
This will force the change of password, and doesnt mess with Verisoft. Now to confirm it's worked go to
Start
Control Panel
Users
Select Change password
in old password type 'welcome01'
in new type which ever you require as your password, it will accept the change.
This worked for me 100%
Cheers
Alan
May 21, 2008 | HP Pavilion dv1000 Notebook
Abt crash dump
To recover your files you will need a 2.5" external sata usb hard drive case. Take the hard drive out of your lap top and install it in the case. Plug the USB drive into another computer with enough space to copy all the files you want to save. Once you have all the files backed up that you need format the drive and re install your operating system fresh. Then load all your rescued files back to your laptop with another external USB backup drive. This is the only way and I know it works because I have to do it every time I thrash my laptop running bad cracks. Please take the time to rate this fixya for sharing my secrets for free. If you need more help feel free to ask.
George
Apr 04, 2008 | HP Compaq Presario C500t Notebook
Computers & Internet Logo
461 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
