Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Temp control pad does not work
The regrigerator is too cold
  • 958 Answers
If you can replace the temperature control pad then that is the answer. it is stuck open.. does not closes as the temperature of the cabinet cools down.
Posted on Feb 05, 2008
When idling the a/C compressor just kicks on for a few seconds then disengages
You need to add some refrigerant (R134). Whats happening is that since it is low on regrigerant the compressor sucks the low side below the cutt off pressure turning off the compressor, then pressure at the low side builds up again quickly and turns the compressor on again then sucks it back down again untill it turns off and the cycel goes on and on untill you add enough regrigerant in there. Here are some caution do not overcharge the system. Overcharging will make it not get cold properly and will damage the compressor costing you a lot more money. The low side should reach a minimum of 35 psi with the AC blower on maximum. This keeps the compressor on all the time. If say you were to put the blower on minimum the evaporator would get really cold since the air passing through it is less. This would cause the low side pressure to dip down gradually until the compressor cuts off, and that is how the system basically works
May 28, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I have a compact avanti regrigerator. It doesnt get cold anymore. What do you think might be the problem? I bought it since 2007.
There are three possible reasons for this;
\the thermostat needs replacing
\The refrigerant has leaked out
\ the compressor has failed
Either way you will need a technician to look at this as it involves an electrical diagnosis
Apr 05, 2011 | Avanti 308YWT Compact Refrigerator
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | GE Refrigerators
I have a whirlpool refrigerator which is running cold freezer or and regrigerator is fine but we are finding water inside regrigerator and seems to be dripping from a cooling box what can i do to resolve...
check the drain hose in the rear area for breaks in the hose or maybe plugged up with mold in the drain line and not able to drain to the lower pan near the floor
Apr 19, 2010 | Refrigerators
My regrigerator is not getting cold
your main control panel is defective,especially if you have possibly blown out some lights in the refrige and the bulbs are fine in the freezer, it ruins the circuit trace on the control board located in the lower left inside wall of the unit in a white case
Nov 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cold enough
yes, if theres a warranty on it, call the place you bought it and have them send out a service tech. you should not have to pay anything.
Apr 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Kenmore Refrigerator not that cold.
How full is the frezzer compartment with product?
Sep 15, 2008 | Refrigerators
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
136 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
