HP does not recognize the DVD drive
In "My Computer" the DVD drive is no longer listed and I can't play DVD's. I have tried running the Microsoft Fixit for this but it says that my system is up to the Fixit's standards. I have tried manually editing the registry via the following:
Select {4D36E965-E325-11CE-BFC1-08002BE10318} at the end of the following path:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters do an Edit/Delete
In right pane select LowerFilters do an Edit/Delete
Exit REGEDIT
But when I get to the end there is nothing that says UpperFilters or LowerFilters in the right pane.
I have also drived uninstalling the device in the device manager. It reinstalls and the computer recognizes it until I restart again. Currently it is not listed in the device manager.
Does anyone know what I can do?
    Problem Solver:
  • 5 Answers
Probably the hard drive could have gone bad
Posted on Jul 17, 2009
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
Wont recognize cd/dvd drive. tried to uninstall and re-install drivers. deleted upper and lower filters in registry but nothing. help!
First use the following steps:
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If the problem remains, open Disk Management. in XP, click Start-> Run
Type diskmgmt.msc and press Enter
If the CD/DVD drive is listed there, try to change the drive letter for the drive.
If the drive is not listed, let me know.
Mar 10, 2010 | HP Pavilion dv6000z Notebook
Dvd drives play CD's but no longer plays DVD's
Hi there!
May be a corrupt driver issue.
Go to your device manager/DVD drives/right-click & uninstall. Restart machine & let windows look for the drivers & install them.
Pls send us your feedback as it's very important for us. Good luck!
Mar 05, 2010 | HP DVD DRIVE DVD Drive
My CD/DVD player no longer works!!! HELP!!
If you are using windows XP, right click on "My Computer" go to "Properties" click on "Properties" it will Bring up a System Properties window. click on "Hardware" tab. in the middle you will see a tab that says "Device Manager" click on that. Look in the list to see if your Cd/DVD drive is shown. If it is and has a big yellow "?" on it or a yellow "?" with a "!" on top of the yellow "?" then the CD/DVD drive is still being recognized by the motherboard. In this case, replacing the driver will most likely do the trick. If you are running Vista, or Windows 7, access the Device Manager by right clicking on "My Computer" then go to "Properties".it will pop up a "Control Panel Home" window. The first entry is the "Device Manager" click on that to open the device manager. From there, the same thing applies to the XP instructions. If the CD/DVD is not listed in the list, try rebooting the system then repeat the process. If the CD/DVD still does not show up, there is most likely a problem with the drive or motherboard not recognizing the drive. If the latter seems to be the issue then taking it to a reputable repair facility might be your only option. If it is the yellow "?" you should be able to find the driver at HP's website http://www.hp.com/#Support once this is downloaded, double click on the file and it should start running the driver installer. Then just follow the prompts of the installer.
Nov 29, 2009 | HP Pavilion dv9730us 17" Notebook PC -...
CD drive not recognized error code 0F00.281A
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program
Click Start, click My Computer, and then see whether the drive is listed.
Is the drive listed? loadTOCNode(2, 'moreinformation');
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
  • iTunes software by Apple
  • Nero software by Nero Inc
  • Roxio Creator software by Sonic Solutions
  • Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD,
If the drive is not listed, remove and reinstall the existing drivers.
Nov 12, 2009 | Dell Precision T3400 375W 32bit Computer...
DVD Drive not being recognized as a DVD drive
That is not unusual.
Several of my CD/DVD drives are listed as CD drives.
They still play and write DVDs.
The problem is cosmetic and not worth spending time on.
Now if you are trying to play a DVD movie you are going to need a CODEC (Coder/Decoder).
Windows XP does not include a CODEC to play DVD movies.
I use Intervideo WinDVD.
I hope this helps.
Aug 17, 2009 | LG (GSA-5169D) DVD RW Dual Layer Burner
Dvd plays initially and then stops
It could be the drivers for CD/DVD.
The best way to troubleshoot this is right click on computer, select manage. A new window will pop up, in that list select device manager.
Look in the list for CD/DVD drives and click on the + sign next to it, when the tree opens right click on the CD/DVD drive and select uninstall, then restart the PC.
This method will hard reset the system and force windows to load the default drivers for the CD/DVD upon restart. Hopefully this should resolve your problem.
If not please post back.
Good luck
Jun 15, 2009 | HP Pavilion DV2740SE Laptop
Compaq V2000 - Service Tag V2220US Only recognizes the CD/DVD drive as "CD" Does not see it as a DVD Drive. Listed as: _NEC DVD+-RW ND-6500A in Device Manager.
Try updating your drivers from www.hp.com
If the issue is that it won't play DVD movies only then you probably need to install or re-install the DVD player software that should have come with your computer. If you don't have it anymore, simply download from HP.
Apr 24, 2009 | Computers & Internet
Dvd not recognized by Windows Media Center
This issue can be caused by a few things. my first suggestion is to delete the upper and lower filters, you can follow this kb document from microsoft http://support.microsoft.com/kb/314060 for step by step instructions on how to do this. If the problem persists try using microsoft's restore manager to go back to a time when the device was properly working. If all else fails you may have to replace the drive.
Jan 25, 2009 | Acer Extensa 4620 Notebook
Cant play DVD ROMs
you can try uninstalling the drive, by going to my computer, right click>properties>hardware tab>device manager and look down the list for cd/dvd drives, click on '+' sign and right click on your drive make and select uninstal. Restart pc and your drive will be reinstalled automatically again. If you have a cd cleaner disc run that also. Try to run the game again, although it may still not work as the drives laser seems to be out of line or simply run it's life, and a new drive is the only answer i'm afraid.
Jun 10, 2007 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
