Question about Toshiba Satellite P35-S611 Notebook
My satellite keeps shutting down. I think it keeps over heating. even if it is only on a short while. what can i do... where can i send it for repairs. ithe unit shuts down when i run more that one internet sight, when watching and dealing with my stock portfolio. it shuts down for no reason. i have lost trades because this piece of ____ won't stay running. i have replaced the batteries, and even added more ram to help out with its speed, but it still shuts down after a short while. My son thinks I should take it apart and re-set the heat sink!!!!!!!!! what ever that means Can someone help.
  • 322 Answers
Go to acer.com, fill a repair form and register your computer, if in warranty they email you with the instructions to send it for repair.
Posted on Jul 17, 2009
My toshiba satellite p755 keeps shutting down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 04, 2012 | Toshiba Satellite P755-S5385 15.6 Intel,...
My toshiba laptop keeps shutting down only when plugged in to the a/c i have a 305-6853. no overheating works fine if running of the battery alone
This is most likely issue with power cord or on the laptop where you plug it in. Try to separate the cord at adapter and just plug it in without being pluged in to power and see does it create short and shut down your laptop and if not it is possible it is not sending right voltage to the laptop it self. Try a different cord if you have one. Good luck
Mar 17, 2011 | Toshiba Satellite A305-S6859 Notebook
I have a toshiba satellite a215 s7422 and it keeps shutting down on me so i disassembled it and cleaned out the fan but it still keeps shutting down...i recently had the bios reset, i don't know if that...
You should look for the following answers.
(1) Are you operating your laptop in a in a hot and dusty environment (If yes you should know that computers do not like hot and dusty environments and they shut down to avoid a complete burn out of the machine more over the dust particles also can destroy the hardware and block internal fan ventilation ducts in between the CPU and the fan).
(2) When the your laptop PC shuts down place your hand underneath the laptop and try to feel hot spots. If you find areas unusually heated then this is the main cause of the shut down.
(3) If just after the shut down and a good usage the Laptop is cool then underneath than overheating shut down might not be the case.
If you determined that heating is the cause and you cannot change your environment than you should look for other heavy duty laptops that are robustly designed for hot environments.
I do not think that resting the BIOS can cause this.
Oct 06, 2010 | Toshiba Satellite A215-S7422 Notebook
Stilleto 2 keeps shutting down
It may be a problem with the power switch, I too had this problem. It seems like the power switch is stuck in "down" position as if you were holding it. I remove my battery cover (along with the battery) and gently jiggle the switch up and down to "loosen" whatever may be sticking it in place and it seems to work. I have encountered this problem several times. I did not send it out for repair. It works fine for me (knock on wood).
May 13, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
Same problem - tv shuts down
Sounds like you've got a problem alright, It's definitely heat related. I would suggest unplugging it and having it looked at by a professional.
I am an electronics tech and can tell you that you should not try to fix it yourself. There are voltages inside that tv that can literally throw you across a room and kill you instantly,
Also, I advise leaving it unplugged until it is looked at, A short can cause a fire.
Sep 30, 2009 | Sony KV-36XBR400 36" TV
Laptop shuts down shortly after boot up
this looks like heat issue...varify that the cpu fan is working.....apply heat sink cream on the cpu surface and the heat sink
keep me posted
May 13, 2009 | Acer Aspire One PC Notebook
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Keeps Shutting Down
First, start by taking the fan and heat sink out and cleaning them. Dust build up can cause overheating. Also check the fan for hairs or carpet fibers that have gotten wound in it, I've had fans stop working due to this. Then put it back together and check to see if the fan is coming on and running in regular intervals. If it's not it will need replaced. If it is, then there may be a malfunction with the processor or a short on the motherboard.
Jul 07, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite p10-832 shutting down
Go to the following link... Best
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1931079&BV_SessionID=@@@@0393765923.1216012797@@@@&BV_EngineID=ccchadeeilhefeecgfkceghdgngdgmm.0
Nov 18, 2007 | Computers & Internet
Toshiba Satellite P35-S611 Notebook Logo
232 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
