Question about Channel Master Televison & Video
Channel Master D2-A Converter Model CM-7000 I have 2 of the above converters. Purchased July 14, 2008 at Fry?s Arlington TX. Neither box contained instructions. I did receive setup help from Channel Master. However I had difficulties when I set up the second converter. My problem is the picture size. #1 converter gives me a full screen on either T V set. #2 Converter gives me a small picture on either TV set. As the broadcast format changes I get a picture with a 3-inch border or a full width but a big border top and bottom. Is there a set up procedure that would correct this problem? Password ? I do not remember giving either converter a password. How can I tell what the password is? Sincerely John Shanks jkshanks@sbcglobal.net
2 Suggested Answers
SOURCE: code for Channel Master CM-7000
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Posted on Jan 10, 2011
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Channel Master Digital Analog Converter Box CM-7000
E1 is a 100 uF 16 VDC capacitor. I have been repairing these units lately and have experienced some of the same symptoms (LED goes red but doesn't transition to green after 30 seconds like it should). I have been able to repair some of these units. Make sure the power supply is working properly before spending significant time on the D2A board. The power supply is responsible for supplying 12, 5, and 3.3 VDC to the D2A board. A defective PS will measure 14.5 instead of 12, 6 instead of 5, and 2.9 instead of 3.3. The AC ripple should be about 5 mV on the 3.3 and the 5 volt supplies when loaded. The 12 volt can be as high as 50 mV on a good PS. The culprits are C12 (1000uf) and C10 (470 uf) which are the filter capacitors for the 3.3 and 5V outputs respectively. C12, the capacitor for the 3.3 V output is especially critical because it is used to feed the voltage regulator and overvoltage shutdown circuit. D7 is a hot part and can also fail sometimes. I have repaired 50% of my units just by changing these capacitors. I still have units where the D2A board is bad with a known good power supply. If anyone has more info on the D2A (like a schematic) please pass it along
Feb 25, 2012 | Televison & Video
My Channel Master CM-7000 D2A TV Converter box is stuck with Red Light ONLY. Does not respond to any button I press. There is no picture
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.
On the power supply I would replace at a minimum:
C14 - 4.7ufd 50v UPW1H4R7MDD
C4 - 1ufd 50v UPW1H010MDD
C8 - 100ufd 25v UHE1E101MED
C10 - 470ufd 16v UHE1C471MPD
C12 - 1000ufd 10v UHE1A102MPD
There are 4 others in the supply that were not grossly bad.
C1 - 22ufd 400v EEU-EE2G220
C7 - 220ufd 25v UHE1E221MPD
C11 - Same as C10
C13 - Same as C10
Logic board:
E5 - 33uf 35v EEU-FM1A471
E6 - Same as E5
Part Numbers of replacement caps are Nichicon or Panasonic.
Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.
Contact me if this is beyond your skills for possible repair.
Nov 06, 2011 | Digi Channel Master/tal to Analog...
I have a Channel Master cm-7000. It won't turn on. The red light is on it won't turn on with the remote or by pushing the on button. I tried unpluging it and pluging it back in and all that happens...
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
Sep 07, 2011 | Digi Channel Master/tal to Analog...
I have channel Master 700 by PCT that the red light will not turn to organge then to green.. It stays red, no matter what I do?
C11 - Same as C10
C13 - Same as C10
Logic board:
E6 - Same as E5
Apr 25, 2011 | Digi Channel Master/tal to Analog...
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
Oct 26, 2010 | Channel Master (9537) Remote Control
I lost all the tv channels on channel master cm-7000 model and do not understand how to get them back?
First look at the indicator lamp on the front left side.
If it is:
off - check the power cord is plugged into a working outlet.
Amber - the unit is in standby, press the on button (left most), it should turn green
Green - the unit is in operate mode, check the antenna and cable connection.
Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
Jun 05, 2010 | Digi Channel Master/tal to Analog...
My CM7000 has a red light on, and won't boot up
Most likely bad capacitors in the power supply. I have fixed several including my own. See avsforum CECB thread for more info
Mar 30, 2010 | Digi Channel Master/tal to Analog...
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
PVS31170Si Trutech TV Is this digital?
I have this model. I believe it is digital because the auto channel select finds numerous (a few hundred) cable channels (I have Comcast cable in Houston, TX) at channel 69 and above, e.g., 77-324, etc. I believe that analog tuners won't do this.
Does anyone have a manual for this TV? I'll pay to have a copy made.
Jan 15, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Televison & Video Logo
182 people viewed this question
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
