Question about Dell Inspiron E1505 Notebook
Inspiron 1525 ac adaptor not recongized
About a week ago i had unplug my laptop and then replugged it back in. now every time i start my lap top i get an error that the ac adaptor is not the right type. the ac adaptor works just will not charge the battery now. what happened and how do i fix this.
    Problem Solver:
  • 7 Answers
Do a system restore to a time before the issue.
start>programs>accessories>systemtools>system restore.
Posted on Aug 06, 2009
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
DELL 1525 laptop boot issue. When switching ON it shows only blank screen. Grateful if you could help resolve this issue
Have you got an external screen you can plug in to prove the video? Try this check list:
Dead Laptop.
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Dell Inspiron 1525 Notebook
Screenblinking blinking
yes replace ac adapter. light on ac adapter does not blink
Mar 07, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1525 Lap top
Mr. Pete Either you have muted the Notebook, which is only a possibility, so do check the speaker icon in the bottom right corner, and check the MASTER,WAVE.... or other scrolls.
If that's ok, then probabbly the drivers are currupted you can get those driver form here.
Kindly do rate, if helpful.
Regards.
Jul 17, 2009 | Dell Inspiron 1525 Laptop
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
How to install windows xp on dell lap top
You have to include your SATA driver into XP. Otherwise it wont detect your Hard drive. You may need a utility called nlite to do this.
I found this article very helpful to install XP on my inspiron
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Apr 23, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Ac adapter
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
The laptop would have to be taken apart and the DC connector resoldered.
This would cost $75 - $100. Enter your zip code in the box on the right hand side of the FixYa page to find someone close to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 17, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron E1505 Notebook Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
