Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Battery Low indicator and Camera shuts Down
When I try to to take a picture I get a red battery low indicator in the viewing window, and the camera shuts down. I hve 3 batteries and they all work the same after a full charge. As long as I am reviewing my photos, the stays powered.
  • 374 Answers
What brand of memory card are you using? Sandisc, Toshiba and Panasonic are the only ones that really work with the cameras. If using one of those trying resetting the camera.
Menu
go to setup
go up to reset
press right arrow
highlight reset
press set
If that doesn't work....Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
Battery needs to b charged
The camera uses most power when you take a picture.
If there's not enough then the camera will shut down, or not operate.
Your manual says charge the battery before first use or when the low battery indicator shows.
You can't start fretting over the camera misbehaving if you don't follow the manual.
Don't forget to format the card. It will work for a while without but then you'll find you have problems viewing and downloading your images. You can even lose them all.
Don't worry about draining the battery before re-charging it...that only applies to Nicad batteries and something called "the memory effect". You have a Lithium battery that can be charged at any state with no problem.
__________
Cegonsoft
Jul 25, 2011 | Cameras
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Low battery indicator with new batteries.
AA alkaline batteries dont have the "power" that is require by the bigger better cameras to take and process pictures. NiMH is the best route.
Apr 21, 2009 | Olympus Camedia E-20N Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
It just shut off....
it normally indicates a problem with the batteries. Try inserting disposable alkaline battieres in the camera and turn it on.
If the lense is still out at the moment try pressing the play button the back of the camera to view the pictures taken, even with a very low battery this normally close the lense properly and enables you to view the pictures.
Nov 15, 2008 | Kodak EasyShare C613 Digital Camera
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Camera shutting off indicating low battery
I had the same problem, apparently if you're using a external memory card that can cause this problem...
I didn't know that but I contacted Samsung and got mine repaired.
They put a note in saying the power board was faulty in the camera.
Much, much better now. I can take pictures like I used to be able to!
May 12, 2008 | Samsung Digimax A7 Digital Camera
Just a quick question (dont rate yet) Are the AAA's alkalines?
Oct 02, 2007 | Sony Cyber-Shot DSC-U10 Digital Camera
Low Battery when using screen
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
