Question about HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 - can't scan to a pdf format
I just installed the new driver from HP, but when I select the wizard for the scanner, I don't get the choice of selecting "pdf" in the document to be created. I've tried uninstalling and un-installing the drivers to no avail.
Please help!
Karen
This is the only solution I found within the software. I went to the actual printer and hit the 'scan to' button. I selected SETUP from the menu options. It pulled up some software on my computer that shows the interface between the computer and the printer. I hit the NEW button. The next screen gave me some options and there was a checkbox option that said 'Show the TWAIN dialog after the scan...'. I checked that box. When I went to the next screen, it offered me PDF as an option and I made that my default. This process sets up a new menu option on your drop-down list when you scan. I named it 'PDF to computer' so I would know to pick it for pdfs. I tried to add it to the list of options available on the printer menu, but the new option I created disappeared after I hit UPDATE. But when I tried to scan something it was showing on my options list. When I tested it, it opened some software I never saw before and showed the image as it scanned, which I guess relates to the checkbox I marked. I've tried several times for hours at a time to find any kind of fix for this that didn't involve converting a file to pdf or loading a different software. This fix I found on my own just by hitting buttons on the printer. If you don't like this option, there is some free software out there that uses the scanner to create pdf's. I just didn't want to go that way.
Posted on Nov 05, 2010
Cant find scanner driver or software for hp 3055
Hi
Use a Normal TWIN driver that appears in any software that allows you to scan or in Windows click on Start, Device and Printers, Select your HP3055 and SCAN
Dec 09, 2014 | HP LaserJet 3050 All-In-One Printer
Can not scan to pdf format.
You need to install a PDF printer driver.
Please click on this link and follow my instructions on scanning and creating the PDF document.
http://www.fixya.com/support/r8627402-scan_create_pdf_document
Aug 03, 2011 | HP LaserJet 3050 All-In-One Printer
Not able to scan may be driver are not anstalled
You probably need to install the driver for the scanner and make sure that the scanner is properly connected to your system too. To know whether it has connected simply, click on your start menu, then go to All Programs, then to Accessories, then select and click Scanner and Camera Wizard. Use this window to detect your scanner but if the driver is not install then you need to install it by looking for the driver online. Thanks
Sep 25, 2009 | HP LaserJet 3050 All-In-One Printer
Can't choose pdf as scanning preference
High wbethsteve
You have to download the driver and the software. It is the software which will allow you to all sorts of things with the scanned image or document.
http://search.hp.com/gwaueng/query.html?cc=au&lang=en&search=++&qt=hp+laserjet+3050&la=en
From the menu on the left, select software and driver download.
Choose your operating system.
Hope this will work for you.
If you are happy give a rating to this answer.
luciana44
Jul 20, 2009 | HP LaserJet 3050 All-In-One Printer
SCANNING ISSUE
You need to install the complete software from HP Website or use the link belows:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1140783&prodNameId=1140778&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
After downloading and installing the complete software you need to set-up scanner.
Using steps and i m sure your issue will be resolved.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Jun 28, 2009 | HP LaserJet 3050 All-In-One Printer
Multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
Click Update .
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
Scanner does not work message Waiting for PC
my hp laserjet 3050 prints but i need the driver to scan a document.
Apr 18, 2009 | HP LaserJet 3050 All-In-One Printer
I have a HP LaserJet 3055. I bought it when I was using XP but I now have a new computer using Vista. I have downloaded and installed from HP the installation setup program for Vista - followed all the...
As i understand that you u r able to print and copy fine which ensure that there is no issue with the connectivity and scanning device.
However next troubleshooting comes in picture is software as per you have mentioned that yoiu have downloaded and installed the complete software couple of times still the issue persists.
In that case we need to Programn Scan to option in the printer software and on your all in one.
HP LaserJet 3050, 3052, 3055, 3390 and 3392 AiO Printer series - How to Program the Scan To Button and Create New Destinations
Information
The Scan To button must be programmed before it can get used. However, some destinations are programmed by default if the all-in-one is directly connected to the computer.
Details
Click Update .
Dec 21, 2008 | HP LaserJet 3055 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Shirley,
If your still looking for a solution, or to those of you who have a similar problem, the following fixed my problem after trying to resolve the issue over the last year!!!!
I also received the "not set up on pc" message and tried re-installing the software numerous times.
Finally resorted to re-installing windows XP (because of this and other software glitches) and re-installed the Laserjet 3050 software again...but could not get the printer to install.
The problem was occuring while the software was asking to "plug in the usb cable", but would not complete the installation. It was not recognizing the device....the solution was to reset the laserjet 3050!!!!
to reset, push the "menu" button, < (left arrow), go to "service", "enter" button, > (right arrow), "Restore Defaults", "enter" button.
This should reset the factory defaults.
After this, I re-installed software, working!!!!!
Puas
Dec 14, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
2,832 people viewed this question
Seeker5211
Seeker5211
