If the Pioneer speakers are of the active type (built in amplifier), you can connect them to the left an right analog audio outputs of your TV. If the Pioneers are passive speakers, you need to connect them to an amplifier/receiver first and then use an interlink cable to connect amp/receiver to your TV.
SOURCE: Can I connect 6ohm speakers to my STAV3350?
Hi , you can connect 6 Ohms speakers to your receiver but you will have to increase the volume due to extra demand from the speaker . This does not arm your receiver at all as long its kept well ventilated to cool it down . All speakers do have different ohms which can vary from 1 to 8 ohms . the higher the number of ohms the lower volume demand from the speaker
Testimonial: "I have been looking for surround sound speakers but couldn't remember what ohm speaker I could use. Thank You"
SOURCE: Hello,I'm trying to conect 4
Well if you look on the back it plainly says speakers should be between 8-16 ohms.
It has facilities for 2 pairs of fronts (A and B) which could be run concurrently if they met the >8-ohm spec.
http://www.use.com/PIONEER_767cb5bb4ea6f30a06fc?p=7#photo=9
http://www.use.com/showorig.pl?set=767cb5bb4ea6f30a06fc&p=6
The JBL's would work best as primary front speakers.
http://www.retrevo.com/support/JBL-CF100-Speakers-manual/id/597bh151/t/2/
If you wired the Bose in series with each other, they'd work as one surround speaker 'pair' electrically, maybe even sonically if you arrange them across the sides and/or rear. I'd experiment.
http://products.bose.com/pdf/customer_service/owners/og_161.pdf
You'll need a separate amp for any center or sub speakers.
Testimonial: "First I want to say Thank you for your help and time "
