Question about Konica Minolta Di1610 Copier
Machine trouble Error light flashes, screen reads "*CAUTION!* Machine Trouble" then changes to "Service Call (C0500)" and then back again.
  • Konica Minolta Master
  • 6,573 Answers
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Posted on Jul 19, 2009
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
C0500 error code
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
C-0500 code mean no power to the fuser inside mid cover front is a micro switch that provides the power to the fuser unit
Jan 11, 2014 | Konica Minolta Di3510 Copier
C0500 error code
Hi, Sir;
I believed this machine come with two heater lamp, change this two lamp position, and also thermistor have to be contact heat roller perfect, try it see what happen. good luck
Error Code C0500
just simply pull-out the imaging assembly and put it back again...the machine will abort then you need to wait the dot on the middle left side of the display on your screen then press number 3 ant touch the trouble reset on your touch screen....
Jan 31, 2012 | Konica Minolta DiALTA Di200 Copier
Can the machine still fixable when it just flashes ERROR light and the note that says: CAUTION Machine trouble. Service call (102H). What do I need to do?
Telephone the nearest KONICA MINOLTA store, and ask for a service-call, i.e., a technician to come and fix your printer.
Oct 05, 2010 | Konica Minolta magicolor 2480 MF...
Machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Sep 13, 2009 | Konica Minolta bizhub 180 All-In-One...
Error Code C0500
Check the Fuser Unit - the part that heats up and melts the toner to the paper.
clean the contacts for the fuser lamp first.
Oct 13, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
power down copier at op-panel.straightend end of paper clip into little hole by op-panel power button.hold in till little dot appears on screen in middle to the #3.that should get you to trouble reset.Or sometimes opening and closing rightside door can reset.
Dec 01, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta Di1610 Copier Logo
560 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
