Question about Sony Audio Players & Recorders
My sony MHC-GX99 stereo will not play my cds.
My sony stereo will not play my cds. It is 1 1/2 years old. Just yesterday it was playing cds fine and i put in a new cd just like normal, and it just continued to say "reading"--"reading"--"reading"--..One second it is playing and the next it won't. Please Help ME!!!
    Novelist:
  • 133 Answers
Some possible causes:
a) dusty laser lens - cleaning it is the solution, you may use the lens cleaner disc (the one that uses liquid), this can be purchased in many shops. I prefer to clean the lens manually, using a cotton stick and some ethyl or isopropyl alcohol (DO NOT use acetone, benzene or similar strong solvents, these will ruin the lens).
b) dirty brush contacts inside the spindle motor (i repaired quite some CD players that had this kind of trouble). They cause the motor to spin with less power so the driver tries to compensate putting more power into the motor, which causes a feedback effect on focus (it may not work properly). The best solution for this is to replace the spindle motor (if you can find one), the second best solution is to clean the brushes and the commutator (that's what i usually do), but this is a pretty delicate and somewhat complicated procedure since you have to open up the motor, clean it and then put it back together in a correct way. I wouldn't recommend doing this unless there is absolutely no way to obtain a new motor (if you are truly interested in learning how to do it, post me a message, i'll explain it).
c) the main power switch has oxydized contacts, which means that the voltage on the primary of the power transformer is a bit lower, and, consequentially, all of the secondary voltages are lower, too. I know it may sound weird, but i had some players in which i cleaned the lens (on BOTH sides plus the mirror inside the laser), opened and cleaned all of the motors, but they would still not work correctly. Only after i've cleaned the contacts on the main power switch did they return to normal functioning. Obviously it's much easier to change the switch to solve this (if you have a spare one). You can check if the switch is the cause if you bypass it (you need to bring the mains voltage directly to the primary of the power transformer, but do it with caution as mains voltage can be LETHAL to you and your CD player - i don't recommend this either if you're not trained in electric safety).
These are just some of the possible causes. It may as well be that the real cause is something else, so don't take any of these for granted, they are just suggestions.
Anyway, i hope you can fix it (or at least have someone do it for you).
Good luck and best regards
3rq8 (triarcuate)
Posted on Jul 18, 2009
I have a mhc-gx99 the sub is not attached. we were playing it pretty loud for about 10 minutes and it just quit. the standby light is now flashing? if i unplug it it will restart and play for 10 or 15...
Chances are, yes, it did overheat. You may have blown out a solider joint on the High and Low voltage supplies. Possibly even weakened them to the point that they need replaced. It would even be wise to test your Left and Right Channel amps.
Aug 23, 2011 | Sony MHCGX99 Shelf System
My sony stereo MHC EC55 does not recognize that there is a disc in the tray. I cannot play CDs.
The solution was to blow our the tray with a compressor. It worked. Then it recognized the disc and functions just as it did before. This saved me a lot of money and time.
Jan 24, 2011 | Sony MHC-EC55 Shelf System
Play Limit
track may be too long!
Sep 22, 2009 | Sony MHC-GN90D Shelf System
I have an Sony RX66 the cd changer will not pop to play on.
My sony stereo rx66 after finish to play the first cd stand of going to play the second one, it put the cds one of the top of the other or under the tray. Can somebody help me?
May 04, 2009 | Sony MHC-RX66 Shelf System
No disc
clean the laser lens maybe got some dust good luck
Jan 31, 2009 | Sony MHC-GX450 CD Shelf System
Sony Mini Hi-Fi MHC-MG110 no longer chooses CDs at random
Unplug the power for a while and load all CDs. It could solve the playing old paylist.
Jan 10, 2009 | Sony MHC-MG110 CD Shelf System
How can i hook up my Sony Mhc-Gx99 to my pc?
ok ive got one of these leads go to any hifi store or computer store and its a headphone jack with a red and white conetor on the other side there very in price from $5-$20 it depends how long and wat brand if u need ANY more help go and send me a message at mid.nightclub@hotmail.com
Dec 31, 2007 | Sony MHC-GX9900 Shelf System
325 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
