Question about Sony Televison & Video
My Sony rear projection tv color changes to black and white every few minutes
techman
  • 3130 Answers
SOURCE: hitachi rear projection tv model 51uwx20b
You have a bad tuner or there is a capacitor bad in the color burst circuit.
Posted on Sep 09, 2007
  • 8 Answers
SOURCE: Samsung Projection TV
You need to take out the DMD bord and open it up then remove the DLP Chip very carefully and blow out under the chip and all the components in the box with dry air something with a dryer on it then reassemble the chip on to the bord and make sure that the three screws that holds the mount that houses the chip are snug then you will need to put the Bord back in and have someone Else watch the pitcher so you can center the pitcher. This happened to me with my samsung tv and ran across this in sum service notes for this problem. Hope this helps
Posted on Jan 02, 2008
video-tek
  • 150 Answers
SOURCE: Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
Posted on May 29, 2009
  • 69 Answers
SOURCE: Sony rear projection widescreen TV. Concave shapes & ghosting
sound like the convergence ics have failed
Posted on Feb 07, 2010
electronick
  • 505 Answers
SOURCE: There is no color and a very loud noise comes from
Sounds like your color wheel has failed. Its right about time, they don't always go bad but do fail regularly. This one uses a bp96-00250a and it costs about $95 plus shipping. You can get one straight from samsung it will come to about $105 after shipping.
http://www.samsungparts.com
Its a little tricky to get it in, and its glass so its fragile, but a mechanical person with a few screwdrivers can get it done in an hour or two. Let me know if I can be of further assistance.
Posted on Jun 11, 2010
The color went out so that now it is black and white. If I turn off the tv for a few minutes it will go back to normal. Then after being on for a few minutes it will change back to black and white. If you...
This is unusual for this model, can you tell me what source you use for signal? Cable? Sat? Direct TV? Also how are you connected----via the coax fitting or the rear AV jacks.
Steve
Nov 01, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Re: Mitsubishi WD62627 projection TV issues
This is the most common problem for rear projection tvs and it is known as the color convergence problem.You will need to replace or repair its ics to solve it.
Mar 26, 2008 | Mitsubishi WD62627 62" HDTV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
Black and white
The bulb is not the problem.Unplug,replug the tv about an hour.Reset the colors setting back to factory setting.The tv work,should be back to normal.Not than ur Signal tuner board have problems must replaced.
Jan 23, 2010 | Sony KP-51WS510 51" Rear Projection...
I have a KP65Wv700 Sony Tv it turns red after a few minutes of watching tv. I turn the tv off and on so see a few minutes of normal colors but start gettinmg red again any ideas
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Dec 14, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
LCD Sony TV - Skwiggly line
Hey there I think the problem is coming from your LCD chips not your bulb, the bulb has nothing to do with the color or skwiggly lines it just shoots out white light,your LCD chips are burnt and the problem will not stop by changing your light bulb you need to replace the OPTICAL BLOCK the skwiggly line will just get worst with time
hope this helps
please rate this solution !!!!
Oct 12, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Projection LCD flickers to black and white
If the S-video cable is not completely in it will do this. You need to remove and clean tips on S-video cable/ replace, this is your problem.
Mar 10, 2008 | JVC HD-52Z575 52" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
