Question about Palm Treo 755p Smartphone
Hard reset How do I hard reset my Treo 755
    Problem Solver:
  • 6 Answers
Re: hard reset
Remove the battery. Then, hold down the red button while reinserting the battery until it comes back up. Let go of the red button and it will prompt you to see if you really want to erase all data and go back to default.
Posted on Nov 20, 2007
Re: hard reset - Palm Treo 755p Smartphone PDAs
GREAT it worked, thanks for your input!!!
Posted on Sep 02, 2008
0 characters
3 Points
I need passcodes yo unlock my daughters palm treo
the only way to unlock the device is to do a hard reset but it will erase all the info in the device :\
Sep 13, 2009 | Palm Treo 755p Smartphone
Treo not turnin on
Sir it can not be repaired by reseting phone you have to update software of phone if does not succes there must be a technecal problem we can do anything if there is a technecal problem in your inside have to visit nearest mobile repair shop thanks
May 31, 2009 | Palm Treo 755p Smartphone
Treo 755 attachments
Problem solved. I called Sprint technical support and they walked me through the process of deleting some corrupted files.
Nov 04, 2008 | PDAs
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
Can hardly see my screen
click the white button and then "p"
Jun 24, 2008 | Palm Treo 755p Smartphone
Treo 755p phone audio stops working
try doing a hard reset just make sure you hotsync first so you can backup all your information. Always keep in mind the software you have loaded write it down and the website you got them from along with any registration codes. when doing a hard reset you will lose all the information and programs on the phone basically it will take you back to the way you first bought it.
How to Hard Reset a Treo 755 To perform a hard reset/clean wipe of a Treo 755, do the following:
1. Remove the battery cover from the back of the device.
2. Press and hold the power (red phone) button.
3. While holding the red power button remove and replace the battery from the device.
4. When you see the "Access Powered" screen on the device take you finger off of the power button. At this point, you'll be prompted to erase the device by pressing up on the directional pad.
Good Luck I hope this helps with your problem
May 27, 2008 | Palm Treo 755p Smartphone
Reset both devices and make sure the IR ports are alinged together so that they are in direct contact with eatchother.
The IR should work 0-10 meters id suggest 20cents from eatchother.
Mar 17, 2008 | Palm Treo 755p Smartphone
Treo 755 not able to make calls
The only workarounds I've read about these issues is:
1. Plug in the headset again and pull it out crisply and see if that works. Another method I heard, is to stick a toothpick in there.
2. Using the OEM Treo mono headset, insert the jack fully into the socket, spin the jack in the socket 180-360 degrees and remove the jack with a quick jerk. If the socket is truly undamaged, this technique, often repeated, seems to enable the speaker.
3. Some report that the headphone jack adapters, 3.5 to 2.5mm, work for this as well, that has NOT been my experience.
4. VolumeCarePro will bypass the headset switch and is a software workaround.
5. Otherwise, the only way I've been able to 'resurrect' the speaker is by hard reset, and once it took two hard resets.
As a result, I do not use my headset jack on my Treo 755p at all any more.
Unfortunately, this is an area that Palm is aware of, but has done little to fix.
is a hard reset
Jan 27, 2008 | Palm Treo 755p Smartphone
Treo 755 keeps reboothin
Do a hard reset. It fixed mine.
Nov 18, 2007 | Palm Treo 755p Smartphone
Treo 755 turns on and off by itself
Sometimes, your bluetooth device may poll (check) for your Treo 755. Also, if you have a data plan, you may have some type of program running in the background.
Sep 09, 2007 | PDAs
Palm Treo 755p Smartphone Logo
1,034 people viewed this question
Top Palm PDAs Experts
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
