Why doesn't it turn on?
The powerligjt flashes but thats it
    Top Expert:
  • Televison & ... Master
  • 49,934 Answers
Power supply failure
Posted on Apr 16, 2016
Wont flash
Check whether the flash is turned on. if it is turned on and doesn't work, The Flash fuse might have worn out. Replace it.
Oct 27, 2012 | Sanyo VPCE1090 Digital Camera
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Jul 01, 2012 | Toshiba Computers & Internet
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
Can't figure out how to turn on flash for my
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/236/ViviCam_X024_Camera_Manual.pdf
Aug 07, 2011 | Cameras
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Jun 14, 2011 | Heating & Cooling
Samsung LN46A650 that cycles on and off with no picture. The red light flashes in the lower right hand corner. Still no picture. Have to unplug power supply to turn it off.
Turn it on and let it run for about 30 seconds. If it still doesn't work... unplug it, wait 15 minutes, plug it back in, then try again. If that doesn't work, you might want to contact Samsung to see if it needs repaired or replaced.
May 20, 2011 | Televison & Video
Turn sign flash fast in front and no light flash in rear
A fast flash usually indicates a burned out bulb. If you no flash in the rear, that is probably the culprit. Keep in mind just because your taillight works doesn't mean your flasher will. Most newer cars have combination bulbs in the rear with more than one filament in them. Try cahnging the bulb in the rear and if this doesn't help, reply back and we can explore this further.
Apr 30, 2011 | GMC Suburban Cars & Trucks
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
