Question about Homedics Sound Spa Premier SS-5000 Clock Radio
Outside temp can't get the right temp for outside. It's 40 outside but it says 68. Also do you have to do anything for Day light savings?
Re: Outside temp
Make sure the unit is not in direct sunlight. It wiil pickup sun heat and transmitt the heating of the unit, not just the ambient temperature.
Posted on Jan 18, 2009
0 characters
3 Points
No outside temp displayed
your temperature sensor battery is bad or the sensor is bad, your if your radio senses outside temp you have bad radio, if you have changed the battery
Dec 07, 2015 | Clock Radios
How do you get the outside temp to display?
sorry no idea what you have , so can not look for any help
Aug 29, 2015 | Clock Radios
My Hammacher Schlemmer Projection Alarm Clock and Weather Monitor will not project the outside temp. It only projects the inside temp. How do I change? Also, can't change the time zone.
No solution but to return it...very annoying product but yet I like the projected display, very sharp and bright. The replacement was much better, it loses connection with outside transmitter often..but occasionally we see the outside temp
Dec 28, 2013 | Hammacher Schlemmer The Projection Alarm...
How do i get the outside temp. to work
If you have a outside sensor add betteries.Wait for it to connect to the base. You may have to "reboot" ,remove batteries from base and outside temp sensor and replace both, Patiently WAIT I have a similar device and once a year I replace the batteries It takes a while for the devices to re-connect and set , the atomic clock as well. That said, How far is the Temp Sensor from the base unit? I set my outside sensor near the base to connect and move it on th outside porch (30' away) out of the direct sun and rain. I not sure if this is necessary but that the way I reset them.
Nov 04, 2012 | Sharp Spc315 Atomic Dual Alarm Clock
Oregon scientific IWA 80055 Outside temp won't display and I have replaced the batteries on the sending unit and it blinks two times every few seconds.
I have the same unit (IWA-80055) and after not finding anything helpful on the net, I just messed with it until I got it fixed. Here's what to do:
1. Take the cover off the back of the remote sensor.
2. Set the chanel to ch.1. (I tried all three but only ch.1 worked for me).
3. Use several tools. (i.e. a stick, needle, what ever you can but you need two) and hold down the reset button on both the sensor and the clock. (at the same time.)
If done right, it should only take a few seconds to start.
The outside temp is delayed at first. Be patient.
Jan 31, 2010 | Oregon Scientific Lwb0997110113004...
Outside temp. display
if it is wireless then check the sender unit
check the battery
severe cold weather can be hard on batteries
Jan 02, 2010 | La Crosse Technology WT-2171-UCS Digital...
I have a skyscan atomic clock, model 88900. I've absoltely LOVED it until the outside temperature quit being displayed. I have changed the batteries 2x's according to the instructions and have used NEW...
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
You can order replacement transmitters from
They only cost $11 and that includes shipping and handling.
Jan 25, 2009 | Clock Radios
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Cant get outside time to work???
I have the same problem with mine. The outside temp displays OK for a while, then it displays two dashs. I unplug the main unit from the wall until the outside temp comes back. I then plug it back in and it works OK. I found that if the remote sensor is located more than 40 ft from the main unit and there are a couple of walls between the two, the outside temp fails more often. I have noticed that putting my wireless phone in it's charging craddle can cause the radio or nature sounds to turn on. I moved the main unit further away from the phone and that cured the problem. Sometimes it will do this if the humidity is low and I build up a static charge and then touch the unit.
Jan 04, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Homedics Sound Spa  Premier SS-5000 Clock Radio Logo
416 people viewed this question
Top Homedics Clock Radios Experts
Gyula Lacz
Are you a Homedics Clock Radio Expert? Answer questions, earn points and help others
