Question about Amana Haier AP125HD Air Conditioner
Amana ac/heating unit model PGD60C1152E
Sometimes the heater blows unheated air. It only happens when the heater comes on the first time in the morning. Turning it off and on several times will eventually fix it, then it works fine the rest of the day.
Repairman have never diagnosed the problem because by the time they arrive the unit is heating normally.
Can you help?
Nathan
  • NathanLAPD Nov 19, 2007
    This is a combination AC/Heating (gas) unit located on the roof.
  • Anonymous Mar 13, 2014
    Ac unit works just fine for cool, but won't heat. The fan blow in heat mode it is cool air. What could the issue be? The heating element or a fuse?
I was having this problem too & like the other person: I believe the fan is coming on before the heater. I just have to manually make sure the light is RED in the Heater/fan section. If its Orange: that means FAN in teh heater/fan button.. Hope this helps
Posted on Nov 22, 2010
It sounds like your blower is coming on before your heat. With gas if your unit is new enough, typically you have an ignition mode to start your heat process, flame recognition, and then full burners, heating up your heat exchanger, and then bringing on your blower. Your blower maybe controlled by a circuit board, just depends upon age of your system.
Posted on Nov 20, 2007
  • 49 Answers
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Posted on Nov 18, 2007
2000 dodge caravan heater blowing cold air only car does not overheat
Feel the heater hoses where they go through the firewall. If they're both hot but you're not getting any heat, your blend door is not moving to mix heated air with unheated air. It could be the blend door actuator not working or the HVAC control unit not working.
Mar 31, 2017 | 2000 Dodge Caravan
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
Jul 18, 2014 | Amana PTH093B35AJ 9100 BTU ThruWallWindow...
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
I have an Amana PBE12 Thru-Wall AC/Heater for my Florida Room. The unit will run for a short time before it trips the circuit breaker. Any ideas?
is the breaker large enough for the unit? this could be the compressor locking up if if it a heat pump style, or sticking thermostat..
Jan 17, 2010 | Amana PBE12 Wall/Window Air Conditioner
2004 GMC Sierra Heater does not heat on low RPM
check your coolant level on the radiator
Feb 03, 2009 | 2000 GMC New Sierra 1500
Heater not blowing hot air display says lo
when the coils freeze up , from intake of outside air, when using the heat pump mode, the unit will try to defrost the coils before going back to heat mode. mine did this alot. does it kick back to heat after a few mins? also after 2 years , mine started having issues with the exhaust blower control and would go into warp mode and bang noise.seems like common issues for this unit.whether the amana, or haier version.
Dec 13, 2008 | Amana Haier AP125HD Air Conditioner
Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Dec 03, 2008 | Heating & Cooling
No heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Feb 21, 2008 | Amana PTH153B50AJ Heat Pump Air...
Amana PTH153B35AK
This often happens if the unit is oversized or to close to a wall or object.
Feb 14, 2007 | Amana PTC153B35AK Air Conditioner
Heating & Cooling Logo
438 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
