Question about Whirlpool Dishwashers
I have a Whirlpool Dishwasher and it is locked and I don't know how to unlock it
I have a Whirlpool dishwasher & locked mine by pushing the "Air Dry" button for about 5 seconds. To unlock it, I pushed it in again another 5 seconds and the unlock light went out & it worked fine. Whatever button you locked it with originally (if you know), should unlock it when held in again.
Posted on Aug 24, 2009
My whirlpool dishwasher is locked and it wont unlock
Need model number to give you more info. If it has a child lock on it hold same for 3 seconds to unlock. You may have a broke handle also.
Dec 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My dishwasher syas it is locked and i don't know how to unlock it
Press and hold HEATED DRY for 4 seconds. The light turns off.
Here is the manual for your series of dishwasher
Link:
Mar 07, 2012 | Whirlpool 24 in. DU1055XTPS Stainless...
DISHWASHER was locked now unlocked but won't run. Goes to drain/Cancel when you push the Normal Cycles
Wondering how you unlocked the dishwasher. Normally you would have pressed Heat Dry for about 4 secs.
I don't this action would have caused the problem. For dishwasher to run you need the door lock switch to operate. If door is not closed it will go to Cancel.
Check item 12 in this diagram.
Oct 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is locked and I don't know how to unlock it. The door opens, but it want start the locked light is on. how do I unlock it?
Hello- Try this: press and hold heated dry button for 5 sec. This should unlock control, and will lock it again if you repeat. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 12, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
I have a Whirlpool Gold "Quiet Partner III" dishwasher. On the front panel a small green light over what looks to be a "lock " symbol has come on and although the door seems to be locked in I can't get...
If that didn't work. I'm trying to figure out what's wrong with my dishwasher right now, and I was looking for the product number on it. And when you open the door to the dishwasher, right on the inside on the top there is a sticker that tells you how to lock and unlock the buttons. On mine it says to hold down on the 'heated dry' button for 5 seconds.
Feb 15, 2010 | Whirlpool Dishwashers
My daughter has a Whirlpool series 930 dishwasher and it is locked? How do I unlock it?
This just happened to me recently on my Whirlpool. My dishwasher indicates that the "Air Dry" button will lock it out if held in for 5 seconds. To unlock it, hold this button in for another 5 seconds or until the lock out light goes out. Hope this helps.
Aug 10, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Dishwashers Logo
804 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
