Question about Goodmans GDVD70W6 DVD Player
When powered up the 6.3 amp psu fuse blows any ideas thanks
  • Goodmans Master
  • 5,568 Answers
Replacing a blown fuse once is necessary, twice to be sure that the first had reason to die, then no more as you could be damaging something in addition to the failed part.
This indicates that something basic in the power supply has turned into a wire. The first thing to check would be rectifier diodes that process the incoming AC; these are cheap and easy to check with any multimeter with an Ohms or diode setting and should measure a bunch in one direction and little in the other. With a diode check range, you should find ~ 500-700 millivolts (units are not indicated), on the Ohms range from several hundred to maximum 1 K Ohm in on direction and off-scale in the other.
Beyond that, you will find possibly discrete transistors or a module (on a heat sink for both) for which you will need the pin-out to roughly measure it. The type numbers are a mix of letters and numbers, the production period will be only four numbers so you need the type number to search for the specs and connection diagram.
If these check out OK, then I think your technician days are over and it's time to let a pro look further. Be aware though, the cost of labor and the potential lack of parts availablity can stop the repair completely so if you can't find something already mentioned, like too many things today, it is doomed to the scrap heap.
Posted on Jul 16, 2009
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
6 amp power board fuse blow when power button pressed.
That is usually caused by shorted output transistors. What brand/model do you have?
Apr 29, 2013 | Audio Players & Recorders
Asrock motherboard no error code display.
No fuse, the protection is in the PSU. A surge will sometimes kill the ram if the anti-surge system (PSU fuse) is a "Slow Blow" type. But the surge may have killed some of the more delicate chips on the motherboard. From your description, it sounds as though you will be able to re-use the CPU and fan. Try the RAM first, you may be lucky. Hope this helps.
Mar 08, 2012 | Computers & Internet
My SI-1230 was not working on channels 5-6 and 11-12. I opened the amp and replaced the fuses on those channels. Now the fuses blow immediately on channels 5-6 and the red protection light is on...
Chances are the main transistors or whatever powers channel 5 and 6 have shorted out. Fuses blow like this when there is an overload and these power types do that a lot. If it uses transistors, then a ohm meter will show them up quick. Because it will be just like you have touched the test probes together when you put them on the terminals, with the meter on the 1K setting. For the reason these parts are just acting like pieces of wire instead of doing their job.
Mar 12, 2011 | Niles SI-1230 12-Channel Amplifier
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
Hi i have a desktop of compaq 1520il model having bestec smps.During switch on it was gave a loud sound & it was not working. when i extrct it from cpu unit & connect it with 220v ac back light was...
You connected a desktop computer to 220VAC?
I assume then, this is not within the U.S.A.?
It sounds like your power supply may have failed, which blew your home fuse.
Feb 05, 2018 | HP Bestec ATX-1956D 200w HP Part No...
Blows 6 amp fuse in top panel. On spin cycle runs the pump but motor wont rotate for spin. If left blows fuse again.
Remove the hoses and check the impeller of the pump for an obstruction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Washing Machines
Short Circut, blows fuses instantly.
OK usually the fuse goes because the Amp's IC's are drawing too much current thus the fuse blows... either this OR the Power Supply has gone Kaput. It is possible to replace the output IC's.. as it is to fix the PSU.. But it really is a shop job..
Jul 28, 2008 | Durabrand 5.1 Surround Sound Computer...
Fuse
There are only a couple of components that could cause the fuse to blow. They are:
1. Reverse protection diode (D23)
2. filter capacitor (C123)
3. Outputs (TR14 & 15)
4. Audio Amp (IC4)
5. Zener Diodes (D22 & 19)
6. the fuse itself (it should be 2 Amps
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Goodmans GDVD70W6 DVD Player Logo
65 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
