Acoustic Solutions backlight comes on then resets TV to Standby
Hi
My brother-in-laws lcdw2610s TV doesn't manage to get a picture as summary says when the power button is pressed the tvs green on light appears as normal and the backlight comes on for a few seconds then turns the set to standby. Glasgow
  • 42 Answers
Probably a burned out transformator in the backlight inverter
Posted on Jul 16, 2009
I have a lcd acoustic solutions tv, the blue standby light is on and when I turn the tv on the white channel number comes up but the screen then goes black, all sound is working ect just no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jul 05, 2015 | Televison & Video
Accoustic solutions LCD42761HDF TV wont turn on from standby. Light flashing of and on. TV approx 4yrs old
acoustic solutions tv model lcd42761hdf with a fault splitscreen how can i fix it please
Jul 18, 2011 | Televison & Video
Acoustic Solutions LCD26761HDF TV turned itself off & standby light started flashing. TV wont respond to remote or on set buttons
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Sep 25, 2010 | Daewoo DLP3212 32 in. LCD Television
Acoustic solutions lcd tv astv15id last used 2 months ago perfect ,switched on today perfect picture but no sound
Hi I know this was posted months ago but the answer may help others, I found the capacitor C852 1000Uf ,35v was bulging at the top which is on the power supply board the number C852 is for the acoustic solutions model lcd42762f1080p tv (but this info would apply to most acoustic tvs: WHEN TESTED THE CAPACITOR ON THE ESR METER READ OK, but cos it was bulging at the top I knew it was faulty, it seems that it was breaking down under load hope this help regards celestica
May 18, 2010 | Televison & Video
Acoustic solutions LCD37NK750HDF TV sound ok but no picture.
If there is no picture, just black screen.. then the cold cathode (backlight) on your monitor is busted. Or its ballast transformer is burnt out. Replace it to work again.
Nov 26, 2009 | iLO LCT32HA36 Television
Acoustic solutions TV,, goes back to stand by when it is turned on,, when it is first turned on , its on standby,, when channel is selected it just flashes and goes back to standby,,
its the analogue board, it is the main processing board in the tv, and typically wil send your tv to standby just before it finally fails completely and you can no longer turn on the tv
Sep 13, 2009 | Televison & Video
Acoustic solutions lcd 22''tv turn it on then it turns it self of
Acoustic Solutions 32 lcd hd Tv screen has green/blue contrast shadows all over the light images on the screen. I have tried changing all the picture setting to no avail.
Aug 22, 2009 | Televison & Video
LCD TV, No Power, No Standby LED, Buzzing sound from Power supply
sounds like either way your power board is bad- do you intend on replacing a component? I would look for Puffy caps- you know- leaking from the top-
Aug 19, 2009 | Televison & Video
Televison & Video Logo
399 people viewed this question
Top Televison & Video Experts
