Question about Miele 23 in. Novotronic G841 Built-In Dishwasher
Miele dishwasher won't drain - Miele 23 in. Novotronic G841 Built-In Dishwasher
I had problems with my Miele G 894 SC not draining, every other day or so, usually after the wash cycle (as opposed to the rinse). I tried using the recommended one tablespoon of soap, as sometimes too much soap is the problem. However I finally found a Miele who identified the problem over the phone. He said it was a common problem on models purchased around 2004-2006. There is a part on the bottom of the dishwasher that rotates and measures water as it comes into the machine. It becomes warped and won't rotate as often as it should. The machine "thinks" it is not getting enough water which causes the drain fault light to come on and shuts everything down. The part itself was around $80, plus the service call.
Posted on Mar 31, 2011
  • 14 Answers
Try removing the pump cover in the sump to see if it is blocked or jammed. it tells you how to in the user manual.
Posted on Aug 26, 2009
  • 177 Answers
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Posted on Jun 13, 2010
  • 177 Answers
SOURCE: Miele g 842sc plus dishwaher
hi,
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Posted on Jul 22, 2010
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
  • 177 Answers
SOURCE: the door on my miele G481 built in dishwasher won'...
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
Posted on May 24, 2010
  • 177 Answers
SOURCE: my miele dishwasher shows intake/drain light
hi, firstly check the filter in the waterproof system where the tap is to make sure it is not blocked. turn off the water and remove the connection with the white box attached this is the waterproof system. remove the black seal and you will see the filter. pull it out with a pair of pliers and clean it.
if this is ok check to see if you have a restrictor on the tap or inside the tap and also make sure water is flowing from the tap prior to reconnecting the waterproof system.
run the unit again and when it is time for the machine to call for water you can manually fill it and see if it works using a saucepan or bucket. if this works ok you may have a stuck waterproof system and probably need to replace this.
Hope this helps
Posted on Jun 26, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
My Miele dishwasher has the red drain light on and won't drain
most common, debris stuck in the drain pump. remove the triple filter, remove the non return valve. clear the debris from the drain pump impeller. try to drain again. also make sure you dont have an obstruction in the drain line. if you replaced your garbage disposal recently, make sure they knocked out the drain plug when they connected the dishwasher. also make sure your dishwasher drain line connects directly to the disposal, and does not run to a air gap in your countertop. miele dishwashers will not function properly when connected to an air gap.
Mar 23, 2012 | Miele Dishwashers
Will not empty water
Hi.
If the machine does not drain you usually have drain blockage. Clean the drain well at the bottom of the tub. remove and clean filter and assembly parts. Make sure that the drain hose at the back of the dishwasher is not kinked.
Several Miele dishwasher uses a pressure switch to determine the water level. A defective pressure switch may prevent the machine from starting.
If this model uses a pressure switch, the switch will be located in the drain line. When a pressure switch is defective the machine should return an error code. Here a picture of the pressure switch:
If that does not fix the problem the pump located under the bottom panel must be tested.
Regards.
Ginko
Dec 15, 2011 | Miele 24 in. G2180Vi Built-in Dishwasher
hi,
Hope this helps.
Jul 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
My miele g886 dishwasher intake/drain light keeps coming on. I checked the filter and the non return valve and drain pump. It all seems ok. I read somewhere that there is a drip pan under 2 bottom panels....
the inlet/drain light is a standard fault light and can mean anything without connecting the Miele dianostic software to the unit. This is only available to Miele service techs or service agents. If the light comes on in the first minute then it is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Hope this helps
Jan 16, 2010 | Miele G892SC SS Dishwasher
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Miele dishwasher did not drain. Discove
Yes - the dishwasher drains into the disposal - if the disposal is blocked up - it will hamper the dishwasher draining.
Nov 15, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Miele 23 in. Novotronic G841 Built-In Dishwasher Logo
2,623 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
