Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Hampton Bay 36" Fan Hums but won't turn
My fan will hum when turned on, but won't turn. I removed the blades to clean them and the motor turns just fine. Usually this fan is on 24/7. What can I do?
  • yogainme Nov 19, 2007
    Same fan (two of them ) newly installed new fans fresh out of box.
    Light motor humming, but no fan rotation
    The company is telling me I need an additional part????
  • 328 Answers
The motor has gotten tired now after being on 24/7. With the blades off, it would turn easily but the weight of the blades strain the motor. You could check that there is proper 110 volt current to the motor because anything less will cause that problem too. You can also help the fan start by spinning the blades while it is on. Short of these suggestions, it is time for a new fan.
Posted on Nov 18, 2007
52 inch ceiling fan hampton bay--Humming..... Tightened blades,adjusted fan blades, changed to a new wall switch, blade to ceiling height O.K.... still humms, what can I do??? thank you
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
Model # yg2047b. I had this fan installed in June, worked fine,now it hums..what could the problem be?
If the fan does not spin and the motor hums, you have a stuck rotor. It may be due to bushing/bearing alignment problem or a lubrication problem.
Try to spin the fan blade manually. It should turn freely, otherwise the rotor is stuck. Remove fan blade and put few drops of lubricating oil on the bushings/bearings and manually turn the shaft to free it up. Alignment of shaft and bushings/bearings must be after lubrication is done and the rotor is still stuck. Move the shaft up and down and side to side until it smoothly spin when manually turned.
Aug 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan hums.............
could be a vibration or the motor going bad try some spray lubricant and tightening any loose screws or connections
Aug 28, 2009 | Hampton Bay 36 In. San Marino in Brushed...
Ceiling fan turns slowly
If you've had it for a few years, the bearings are probably getting bad (dry).
Always start a fan on high---then go to the speed you want, only the high speed windings will handle start-up.
Apr 26, 2009 | Dryers
Hampton Bay 73554 (56-ANT) from Home Depot
You need a new motor, are you still in warranty?
Oct 26, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay San Marino 36" Ceiling Fan
18 gauge is a little light... should use 14. Are you sure it is a hum, or is it possibly the fan resonating due to imbalance of the blades. Watch to see if the fan is oscillating when it runs. Also, does changing the speed affect the frequency of the hum. If this is the case, you have to balance the blades using metal shims.
Sep 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Ceiling fan power
It sounds like the fan motor has blown out. Is this an old fan? The motors do burn out every 5-10 years, depending on the brand and quality of motor.
Apr 14, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
590 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
