SOURCE: 02 yamaha vstar 1100, ran fine. started it the
Sounds like it may be drawing air around the intake somewhere. Let it idle and spray around carefully with wd-40 until it speeds up. This will reveal the leak.
SOURCE: 2002 yamaha 650 vstar, 20,000 miles. it won't
Could be the coil. Also could be several other things. Download a shop manual and diagnose it.
SOURCE: Tire pressure vstar yamaha 2003
that all depends on what brand of tire you have on the bike,, check the sidewall of the bike for proper tire inflation , if you can't locate it,, send me the tire size and brand of tire, and I'll try and locate that info for you , just reply to this answer
SOURCE: what type of oil filter will fit a 2007 yamaha vstar 1300 other than yamaha filter
I use fram PH6017A. Get them at wall mart 6 or 7 dollars. about ten.or twelve dollars cheaper than one from yamaha also longer than stock so insted of 3.6 qt of oil I use full 4 qt. Hope this helped. Ride safe and have fun
