Question about SanDisk Sansa MP3 Player
My Sansa Sandisk MP3 player is not getting started also!!
It was working ok 10 minutes ago, but now its not even switching on. On pressing the power button, It shows the name 'Sansa' on the screen and thats all, nothing further. Even when I connected it to my PC, it isnt showing up and simply not working.
Its a pretty new one, I havent used it properly yet and its already showing up this PROBLEM. Can somebody please help.
Thanks
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (and be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Posted on Jul 22, 2009
Will not turn on
To reset your Sansa Mp3 player.1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present. You will lose all your music - sorry. For the Sansa Clip: 1. From the Main Menu, in the player -> select Settings -> Format. 2. Select Yes. You can also format using Media Player if you have unfrozen your player.1. ->start Media PlayerIf you have Media Player 10 --- Connect the Sansa player to the PC in MTP (See next step to change to MTP mode) . 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC with the USB cable. once you have done that... Click on the Sync tab.(be sure your player shows in the pull down menu)Click the pencil icon on the upper right corner of the window.Click OK to start formatting. Now if you have Media Player 11---Click the Sync tab.On the left panel, look for the device. It is usually the last device listed.Right-click on the device and select FormatClick OK to format.
Apr 16, 2010 | SanDisk Sansa Fuze MP3 Player
How to unfreeze mp3 player
I would recommend you to upgrade your device firmware.
This will fix the issue.
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa MP3 Model e280 has frozen with the message refresh data base on it. I have turned it off and turned it back on again but it the message won't clear. I have even let the battery run flat and then...
Check out my tip on your problem -->
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format <-- copy the address into anew window.
Feb 15, 2010 | SanDisk Sansa E280 MP3 Player
Refresh Database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Dec 22, 2008 | SanDisk Sansa E280 MP3 Player
Help please
Thank you
Computerrep
Apr 25, 2008 | SanDisk Sansa e250 MP3 Player
Wont load
hi try this
1 with mp3 player off switch lock/hold button to on
2 press and hold rec button on left hand side keep held down
3 switch on whilst still holding down rec
4 it should now say recovery mode
dont do nothing now dont connect to computer before you do this goto sandisk website and download the latest firmware once downloaded open the file then it will take you through the process of updating the firmware ok
let me know how you get on ok and if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player display gone blank
I believe this is answered already. Turn the hold button on. Red light will be on. Hold the rewind button while you insert it into the computer. Please search online this has been answered. I am recalling from what I read a few minutes ago.
Feb 04, 2008 | SanDisk Sansa e250 MP3 Player
Try Holding the Power Button for 20 sec for a Power Reset of the device Turn on the Player ,hold the Power button for 5 sec.
Oct 03, 2007 | SanDisk Sansa e250 MP3 Player
It won't start now!
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 22, 2007 | SanDisk Sansa e260 MP3 Player
My sansa e250 frozen
That happened to me. Take the battery out and then put it back in. Mine worked fine after that.
Nov 29, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
