Wear can I buy parts for a rca rs1289 stareo the part that I need is the motter that turns the cd tray on a 5 **** cd player?
    Problem Solver:
  • 18 Answers
You can try THE Parts Store .com and enter your MFG and Mod numbers,
Posted on Jul 24, 2009
RCA 5 disc changer tray want open
It will be due to the end of the player
Aug 20, 2016 | RCA RP8078 5-Disc CD Changer
Need to get belt kit for the RCA RS1289
Go online to rca, contact customer support and technical department. They should be able to provide the belt kit. The second option is go to a rca dealer nearest you. The third option is to bring all the belts down to a tv repair shop and have them size up, using a belt gauge. This would be the cheapest approach.
Apr 09, 2012 | RCA RS1289 Shelf System
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Dan
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
I need to make my speakers wires longer for my RCA surround sound
If your speaker have wires that are hooked directly to the speakers and there is no terminal, you will have to splice new wire onto the existing ones. Be carefull and use crimp connectors, available at Radio Shack, these connectors are best because they will keep the speaker wires from touching and damaging your unit.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | RCA RS1289 5-Cd Changer Mini Systemwith...
Every time i turn the stareo on it shows f61 then it turns off
your panasonic is in service mode, only pansonic service center can fix that problem..
Jun 18, 2010 | Panasonic SCAK410 5-Disc CD Changer
My rca rs 1289 5- cd changer mini system will not play, open, close, or change cds. how can i fix this problem at home?
Remove the case screws on the left and right side panels. Pay attention to the long screws that come out of the middle of the panels to make sure they get back in the right spot. Remove one screw from the top rear back panel. Lift side panels of in a hinged motion from the bottom. Remove the top panel in a hinged motion from the rear. In the center of the disc tray remove 1 screw from center. Note the orientation of the tray for re-insertion. Lift the tray up and out. look for small dc motor and spindle. this motor is used to spin the tray. You should find a black belt2_bing.gif between motor and spindle. Make sure it is in good condition. Look to the right rear of the unit. there is a second motor and belt which drives the tray. This belt may be broken or off its spindle. repair or replace the belt as necessary. Plug the unit in and test the open/close function and ensure the gear train, belts2_bing.gif and carriage move smoothly. reassemble.
Apr 11, 2010 | RCA RS1289 5-Cd Changer Mini Systemwith...
5 disk CD player stopped working, won't engage, no longer hear it engage mechanically. How do I open manually to get CD's out?
This eventually tends to happen with most players in their time. The motors or laser circuits tend to wear out. You will have to manually pull open the dvd tray to get cd's out.
Aug 14, 2009 | RCA RS2056 Shelf System
Same thing
this unit needs a mechanical alignment, I have worked on enough rca's to last a lifetime...the cd tray is not chucking properly//it should load and you should hear the cd mech chuck down..if it is not chucking properly..it will open randomly..you can fix this by jamming it shut with the power off
Jul 28, 2009 | RCA RS1289 Shelf System
 Grubhead
Grubhead
