Question about Refrigerators
I have a 1990 RCA fridge model #MSX22DMC. The door no longer closes on it's own.
2 Suggested Answers
AndrexT
  • 14599 Answers
SOURCE: We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Posted on Dec 30, 2016
Dec 30, 2016 | Refrigerators
HAVE A KENMORE REFRIGERATOR - MODEL # 253.60734407 - HAVING PROBLEM WITH THE MAIN DOOR STAYING CLOSED. IF I PLACE 2 LITES OF SODA ON THE DOOR. THE DOOR WON'T STAY SHUT. HAVE THERE BEEN ANY OTHER...
The main thing that makes a fridge door shut is that it falls shut because it is set at a slight angle with the front of the machine higher than the back. You may find the solution is as simple as making the fridge tip back a tiny bit more by turning the front feet clockwise to screw them out of the chassis and make them longer, causing the fridge to tip back a little and the door to fall shut as it should.
Jul 07, 2011 | Kenmore Refrigerators
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Hopoint fridge freezer model ff78p - fridge is not cooling
check the damper door vent between the freezer/refrigerator compartments and make sure this door is opening and closing as you adjust the cold control in the refrige section,it may have a diverter cover on it but you should feel cold air flow in this area even if its only open part way,then remove this cover and check that its not iced up if so use a hair dryer carefully and deice it,then try the control and see if it opens and closes as you adjust the cold control in the refrige
Mar 27, 2010 | Refrigerators
Whirlpool refrigerator side x side doors make a popping noise if opened past halfway... model GS5SHAXNL00
The door closing cams were worn on both doors. I had to buy a cam kit that cost about $10.00 and had the parts for both doors in it, take off the doors, and replace the cams. Before taking off the door that has an ice and water dispenser, I had to turn off the water to the fridge, take off the front grill, and disconnect the water tube that goes into the door (as the tube is threaded through the door cam). After replacing the door closing cams and reassembling, there is no longer a popping sound.
Jun 10, 2009 | Refrigerators
Freezer door hard to close
Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
Mar 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Hotpoint FFS70 fridge problem with draws.
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Jun 12, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
