Question about AudioBahn A2300HCT Car Audio Amplifier
I'm working on an audiobahn A2300HCT and it seems to have a dead short in the front end of the power supply (The fets,caps and rectifiers will all have to be pulled, one at a time.Any suggestions?
  • 655 Answers
Hello rick27,
I'm assuming that you have already pulled the board out and cannot visually locate any out of place looking component and that you've inspected the board for solder bridges, broken pieces of wire, and other signs of FOD.
If this is the board you are looking to troubleshoot, I'd start nearest the fuses and work systematically from there. You can test many components if you just remove one lead from the circuit. Both diodes and capacitors can be field-checked quickly with one lead disconnected.
Posted on Jul 17, 2009
Heeey. I have the Audiobahn A2300HCT and it has a very strange problem. When i start the amp its in the normal blue mode but i have no sound. The one power output (LEFT) indicator shows +3DB (full) the...
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
Apr 08, 2010 | AudioBahn A2300HCT Car Audio Amplifier
No power ,all fuses are fine
More than likely the power supply has gone bad. I do not know if Denon uses a switch mode power supply or a linear supply. One way to tell is the weight of the amp. Heavy = linear supply and light = switch mode. Common problems with switch mode supplies are the FETs used for switch or the PWM generator (pulse width modulation generator) Linear supplies more than likely would have a bad bridge rectifier or shorted bypass cap on the DC rail.
Feb 06, 2010 | Denon AVR-2500 Receiver
Reversed 12 volt and ground wire when i installed it...now the red light is on AudioBahn A2300HCT
check for a short or burnt trace by the negative (ground traces) on the power side of the board
Jul 04, 2009 | AudioBahn A2300HCT Car Audio Amplifier
HEY I HAVE 4 GAUGE GROUND & POWER THAS WHAT THE AMP ALLOWS. I TRY 0 GAUGE BUT IT IS TO BIG FOR THE AMP. A2300HCT.
Hello again VICENTEMULGA,
Audiobahn's website has apparently been shut down and it's my understanding that they are no longer manufacturing any new products. And not supporting the old ones, online anyway.
But I did find this site that sold the A2300HCT and still have the specifications listed. The 3rd from the bottom in the description shows "1/0- or 2-gauge power and ground leads recommended".
At the very least, you should consider running 1/0 or 2-gauge from the battery to a distribution block and then run a very short jumper from the distribution block to the amp.
May 05, 2009 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A2300HCT no sound
Generally, if the amplifier smokes, the power supply FETs have failed.
Many times, the output transistors fail and that causes the power supply FETs to fail.
Audiobahn won't release schematics. The amplifiers are relatively simple and a schematic isn't generally required.
If you know how to check the transistors, check them to determine the severity of the damage. If you don't know how to check them, read through the following page following all links provided.
Basic Amplifier Repair
Let me know if you have any other questions.
Sep 04, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn powered subwoofer
yep, they dont make audiobahn any more i think they still make other subs to one of them is DUB subs, ebay is the best place for me to find audiobahn, and for parts...
Jul 24, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A2300HCT Car Audio Amplifier Logo
193 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
