Question about Kenmore Dryers
Dryer fuse and thermistor continue to burn out
For the past two years, our Kenmore electric dryer, Model 110.62982100, which we have used for six years, continues to have a problem with the thermistor and thermal fuse needing replacing--a total of five times we have replaced ourselves in the past two years. The metal flexible venting has a 20 degree turn at the bottom of the vent from the dryer, up approx 2 1/2 ft. into hard metal which vents to the outside. The distance from the back of the dryer to the outside vent is 12 inches. There are no kinks, no lint anywhere-allventing clear. Have cleaned the inside of the bottom of the dryer--everything cleaned out-continues to fail after using for about three to four months-last time lasted six weeks. We have also replaced the thermal cut off and the thermostat once, about a year ago when the thermistor and thermal fuse were replaced. I measured the ouside vent and it is 3 1/2 inches across-blows well. Any suggestions of what else to do? My husband says to get a new dryer, but other than this problem it looks brand new.Thanks
    Genius:
  • 1,122 Answers
How about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Posted on Jul 17, 2009
My electric dryer doesn't heat up
Whats the model number and brand.
Fix should be straight forward.
a) One of your safety switches is burned out. Example Thermal fuse, Safety thermostat etc. Or Thermistor problem. Cheap fix.
b) or your Heating element is burned out. Mid price range repair.
c) or computer board relay problem. Repair could go up to $ 300/= plus with parts and repair labor.
From Service experience.... If it is SAMSUNG most likely the heating element. If is Whirlpool or Maytag then Thermal fuse or Safety cut off.
If the failure is due to safety switch failure, then after replacing the safety switch you have to check your lint exhaust line to make sure the line is clear. It may be blocked and thats why the safety has burned out. Though not always.
Sep 26, 2014 | Kenmore Elite HE4 Electric Dryer
KENMORE ELITE ELECTRIC DRYER MODEL 110.8586 BLOWING COLD AIR.
Hi Randy Meloy...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Bud
Sep 22, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer wont heat model super capacity 41788052700
Hi Warren
Check your Wiring
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Bud
Oct 16, 2011 | Kenmore Elite HE4 Electric Dryer
I have a mid 90's Kenmore electric dryer with no heat and no model #. I bought the set used I have replaced the drum belt and door sensor with luck and the old parts. Can you check this deflector part...
Hi sjh41 shirl...
Open your door and look on the main frame of the dryer, your tag with all the numbers should be in the area where the door seal will go.
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
Please take time to rate me thumbs up
Sep 19, 2011 | Kenmore 74962 Gas Dryer
My Kenmore He4 electric dryer is not heating. It is running fine, but does not heat to dry the clothes. What do I need to do?
Hi tomsavaloja...
Check your Wiring
Sep 15, 2011 | Kenmore Elite HE4 Electric Dryer
Electric dryer won,t heat/replaced heating element last year,dryer worksbut won't hea
Hi galepezz...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Jul 25, 2011 | Kenmore 62602 Electric Dryer
I have a kenore series 80 electric dryer that will not heat. It runs but no heat ,blows cold aor/ model 11060832990 serial # mk0223061 Please tell me what might by wrong and what year this dryer might...
Hi julienron...
Check your Wiring
This is a FREE answer, Please take time to rate me
Jun 21, 2011 | Kenmore Dryers
10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
Feb 21, 2010 | Kenmore 63942 Dryer
29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 03, 2009 | Dryers
Kenmore Electric Dryer will not Heat
Define checked everything. Usually when your dryer is not heating but blowing air its one of three things...
1. Thermal fuse in dryer
2. Thermistor in the dryer
3. Heating element in dryer
You need a signal meter with continuity check to accurately test all three componets. Normally the fuse and thermistor are in a set and cost less than 25 bucks. They are easy to replace if you are good with taking things apart. If the element is bad then you need to make sure your lint trap and exhaust hose are clean and kept clean. That is the main cause of the element burning up when it gets lint collected inside the dryer cavity.
In a pinch if the element is bad you can simply find where the metal has broken and try bending the rod so that it touches. The element has to be one solid piece so if there is breaks try and connect them back together until a new one can be purchased.
Please unplug the dryer before doing anything mentioned above.
Hope this helps
TankMurdock
Apr 27, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
320 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
