Question about Craftsman Garden
Tiller starts but dies when you try to run it full speed.
  • 112 Answers
Could be dirt in the bowl of the carb or high speed needle needs adjusting (unscrew or out) or gas cap is not venting correctly.
Posted on Jul 17, 2009
5 Suggested Answers
jj505
  • 195 Answers
SOURCE: Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Posted on Mar 28, 2009
jelsegood
  • 32 Answers
SOURCE: Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Posted on Apr 06, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
  • 8404 Answers
SOURCE: Troy built tiller starts chugs along and then kills full size mod
I'm sorry you are having trouble with your Troy-Bilt Tiller. I have a genuine Troy-Bilt and I miss the original manufacturer and the help they provided me with my 30 year old machine.
I believe your trouble is in the needle valve adjustment. If you check the bottom of the carb, you will find the needle valve. It should be open about 1 1/2 turns and then fine tuned open or closed a bit to get the best speed. There is the possibility that your carb is dirty inside and could benefit from some carb or injector cleaner. You may also benefit from installing a new spark plug as well. Sometimes, in older engines, you can benefit from using a spark plug one or two heat ranges higher. You will have to experiment with these options to find the best for your situation.
I hope you find these suggestions to be of some benefit.
Thank you for posting your question on FixYa.com
a
Posted on Nov 07, 2009
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
Honda fg100a wont stay running full of fuel and oil
I had a similar issue. Tiller starts and runs for 20 secs. or so then dies. Found the problem! In turning the tiller on its side to check model numbers etc. the fuel line had shifted inside the tank and was stuck just about at the TOP of the fuel level. When I gently pushed the fuel filter and line back to the BOTTOM of the fuel tank, the tiller now runs beautifully! So, check that the fuel line placement inside the fuel tank is correct.
Sep 29, 2011 | Honda 25cc 4-cycle Mini Tiller
Cannot get full throttle out of honda fg100 tiller engine
I have the same FG 100 tiller with the same problem. I did replace the carb with a brand new one and still can not get full RPM. It does try to go to full RPM, but drops back. I even checked the transmission and clutches very thing works very well.
Jun 26, 2010 | Honda 25cc 4-cycle Mini Tiller
Will run with full choke on but once i turn choke off it dies
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
May 23, 2010 | Mantis 2-Cycle Tiller
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Dies out at high rpm
bolt on bottom of fuel bowl is actually a metering jet.take to lawnmower parts supplier to get replacement $7.00 appx.
May 08, 2009 | Mantis 4-Cycle Tiller
Apr 06, 2009 | Maxim Garden
Mar 28, 2009 | Garden
Garden Logo
145 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
