SOURCE: Speaker act more like tweeter only, not mid range + tweeter
They are mid Hi speakers.1st Open them and check if the mid speakers are ok maybe they are defected or the protection is open. Good Luck Toufic Malek
SOURCE: Tweeters poked to death
I know this sounds silly, but I had the same problem. Your speakers have a little plastic bulb that has been pushed in, right?
If so, simply put your mouth up to the tweeter, seal with your lips and **** gently (seriously). The tweeter dome should pop back out and in to shape.
It worked for me.
Good luck.
SOURCE: hi i am looking for some motorola tweeters for dj
If you're looking for new tweeters, I'd start at e-bay, see if there's any that are matched with yours.
If not, look for (I presume) compression drivers, with the correct sensitivity (sound output at 1 watt) to your woofers. You may need to purchase an adaptor to make the new ones fit the horn.
Also, try to match impedance - if the old ones were 8 ohm, look for new ones that are 8 ohm. Use something different, and the crossover point won't be what's intended. It will either come in an octave too low (the tweeter would die) or too high (big hole in the frequency response).
SOURCE: Find original replacement tweeter for HB1
just buy the same wattage rating, same ohms rating and most specially the same diameter, price depends from the name, there's a lot on the internet
