Question about HP 920 Plain Paper Fax
My machine pulls more than one sheet at a time.
Paper feed section is worn. Rollers and/or separation pad(s) need replacing
Posted on Jul 17, 2009
    Problem Solver:
  • 9 Answers
You can get these parts from Worldoffax.com
Posted on Nov 24, 2009
I have about 10 sheets of paper jammed in the machine. How do I loosen them to pull them free? Its model MX495
First unplug the printer, open the printer up by pulling the piece of plastic in front that says Canon toward you and then remove the paper one sheet at a time slowly.
Jun 14, 2017 | The Office Equipment & Supplies
Paper feeder pulls multiple sheets of paper
PULL ALL PAPER OUT OF MACHINE EVEN THE SUPPLY, UNPLUG OR TURN OFF THE POWER TO THE UNIT, PUT A STACK OF PAPER IN THE SUPPLY TRAY & GENTLY PUSH FORWARD NOT FORCING IT UNTIL IT STOPS. TURN POWER BACK ON & TRY AGAIN. YOU MAY HAVE TO REPEAT THIS 2-4 TIMES BUT IT WORKED FOR MY HP DESKJET F4180 ALL IN ONE.
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
Every time i ask for 1 print. the machine pulls a 2nd sheet of paper .the 2nnd one gets jam inside. if i ask a report (1 sheet) it always pulls 2. i blow air in all the sensors,got no effect. im starting...
...I'm starting to think the feed rollers clutch can be the cause..
Yes, it is!
(Dal nome credo che tu sia italiano, dunque il problema sta nel gommino antirumore che si trova sul solenioide presa carta che fa rimanere incollata la leva di sgancio. Basta che lo togli e hai risolto.)
Ciao
Mar 11, 2011 | Brother IntelliFax-2820 Laser Fax
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
Action : Remove the paper according to the following procedure.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Non visible paper jam
Fixed the problem by running two sheets of heavy card stock through at the same time.
With the machine off, positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When turned on the printer, it drew the two sheets through and this reset the paper sensor. Previously found that only one sheet at a time did't work.
Aug 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Putting out extra sheets
Do you "fan" your paper when you fill the machine? paper will adhere together, unless you " grab any corner of the fill, pull towards that same corner to allow air to get between the sheets.
Feb 04, 2009 | Brother MFC-8840D All-In-One Laser Printer
Lexmark X7170 not ejecting printed sheets
Time to get a new printer, because you cannot get the parts.
Mar 01, 2007 | Lexmark X7170 All-In-One InkJet Printer
HP 920 Plain Paper Fax Logo
256 people viewed this question
Seeker5211
Seeker5211
