So, after an event in museum, some kid decided to play a prank and lock the projector with a password. And now we are one projector short, since we can not use it. Local IT firm, didn't help (benq refered us to that firm for questions). The code is: 222772 13898 6789 8507 How can we get the unlock code?
SOURCE: BenQ MP610 password???
Hi, i have a problem with MP610 i lost password and i can give you the code num 22654 15072 7440 9690
SOURCE: I forget the password for the projector BenQ Mp620 Datashow
u need to re install the the setup of ur projector through net ..
jus connect to net and run sofware updater , it will refresh ur password ..
SOURCE: BENQ MP610 Lost password
Hi, Hi, i lost my BenQ password, the decode number is 20648- 13770-6789-8379. PLease help, thanks.
tolong klo ada yang tau cara gimana mengembalikan fassword yang terkunci di layar projector BENQ MP620
SOURCE: Hi,I have a Benq mp610
The default password is 0000. If you manually assigned a 4-digit password, and forgot it, you will need to follow the password recall procedure.
If you forget the password:
You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure.
To enter the password recall procedure:
Press and hold Right for 5 seconds. The projector will display a coded number on the screen. In this case your recovery code is: 22135 - 15520 - 7440 - 10130
Your recovery password is: 7771
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
And our problems with Benq didn't end there. On MP620c projector buttons are "locked up" suddenly. Only "Power" and "Source" buttons work.
