Back to:
Tags:
Daewoo DSP4210GM 42 in. Plasma Television
Broken plasma screen
posted by swan786 on Nov 18, 2007
hi can you please advise where in birmingham u.k i can have my plasma screen replaced as it has been smashed although the plasma itself is in full working order.
i look forward to your reply
e-mail adress: shuja12@hotmail.co.uk
kind regards
sean
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 04, 2008
Not Rated (0)
Eric2009
Rank:Wiz Wiz
Rating: 84%, 19 votes
You can have them repaired using a TV Repair guy but often it costs as much as a brand new plasma. My daughter broke my 1600 LCD. It would have cost 1200 to fix.. so I just bought a new one. I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect you TV from damage. Now I dont have to worry anymore when she is playing near it.
Eric
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on broken plasma screen:
I don't want to Accept this solution
Solution #2
posted on Apr 27, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It is to expense to replace, I have talked to Daewoo parts and it cost about 2000 dollars for the panel. Better off finding another broken tv, that does not have a broken display panel and fixing yourself.
Thank You!
Can you Help with these Flat Panel Televisions problems?
I am getting really bad picture on my plasma. Its really...
dfgdfg
Hi, Could someone please help me. The tv was working fine...
i have loads of pixel lines on my screen---can it be fixed
picture has gone pink on me done it once before had it 3...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
