Question about Hitachi 51F59 51" HDTV Projection Television
Alignment is broken on hitachi hdtv
The alignment is off you can see two images one is the real image and then there is a blue image overlapping something burnt out on the TV i smelled smoke
  • jackles18 Jul 22, 2009
    are the convergence ICs hanging. and i think i have three of them. where do u find the number STKXXX-XXX?
    President:
  • 788 Answers
Your symptom sounds like at least one damaged convergence IC.
You are correct you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend to replace them both at the same time because the chips legs can fall off due to the heat of the IC.
Please be sure to remove all of the white heat sink compound on the heat sink and apply a even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I believe that your set has two. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact Hitachi part, or Sanyo, even though the numbers on the front are the same, and they look exactly like the $10,00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 17, 2009
  • John Snow
    John Snow Jul 27, 2009
    They should be on the IC's them selves in large white numbers.
Why does my hitachi rear projection tv has double image?
Are the double images different colors, such as red or blue or green? If so, the projection unit is "out of convergence, meaning the images are not superimposed on one another. That requires a convergence generator, also known as a video alignment generator.
Apr 28, 2017 | Hitachi Televison & Video
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Blue haze around images.
It sounds like your drive jets are out of alignment. Ask your local TV repair places what they charge for re-alignments.
Aug 24, 2011 | Hitachi 57F500 57" Rear Projection...
Red and green snow near the sides of the screen
As in there's blotches of red and green at the edges, but the image is still there?
If so, then your screen may have come into contact with magnets, or maybe the alignments are off (TVs align overlapping images in red, green, and blue).
As always, check with the manufacturer support lines, as they would have specific information for these kinds of scenarios.
Jun 03, 2010 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Image of picture has blue color overlaping the other colors
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Rcs hdtv multiple images
The problem you're having is due to the failure of the convergence amplifier circuit. In that circuit are some components which amplify or control the signals to the dynamic convergence yokes, which line up the red green and blue images to superimpose them over each other to create a proper colour picture. When you get a failure in that circuit, it no longer aligns the images properly, and generally you get what appears to be badly set geometry in multiple colours. In some cases you will also get a problem with the part of the power supply that supplies the convergence amplifiers, or the digicon, which is the digital convergence control module.
Jun 12, 2009 | Hitachi 43FDX01B TV
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color distortion
Hi, could use a little more info, if your seeing red, blue, or green colors overlapping the image then your convergence IC`s have failed, if thats not what it`s doing please reply with more info about the symptom, video-tek
Feb 08, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Hitachi 51F59 51" HDTV Projection Television Logo
151 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
