Question about Dryers
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
    Brigadier General:
  • 4,088 Answers
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Posted on Jul 16, 2009
5 Suggested Answers
SOURCE: G.E. WHIRLPOOL DUET DRYER MOD.# GEW9200LW0
I had the same issue, pressed the End of Cycle button (held down for 3 seconds, it beeped and it reset). The button is cryptically labeled Hold 3 seconds for control unlock - works great now. Pain in the a$$ to figure out.
Posted on Mar 19, 2008
SOURCE: Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Posted on Jul 18, 2008
aasc
  • 1606 Answers
SOURCE: Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Posted on Jul 22, 2009
Macmarkus
  • 2605 Answers
SOURCE: BOSCH DRYER #WTL5400UC Thanks Gentlemen, All power
Welcome to FixYa.
Based on what I've read of your post...I'd suspect the hi-limit thermostat is tripped if it is indeed a WTL series Bosch.
I'm not clear as to whether or not you located the hi-limit safety, reset it, or ruled it out so I'm going to explain what to look for and what to do when you get there.
**Unplug the unit from the wall or switch off the breaker...safety first**
Once the dryer has been disconnected from any power, remove the rear panel...
i.e.
Once the panel has successfully been removed, you'll see the heater with the Hi-Limit and NTC attached. The Hi-limit is the thermostat with the red button in the center...
i.e.
push it in to reset it. As you can see by the images I've provided, if you have a multi-meter or ohm meter you can verify the proper values of the listed components.
If the hi-limit is tripped, obviously something triggered it, you can check the possible culprits such as the NTC's or heater with the info I provided above as I alluded to.
( Even so, I'd suggest running it through a cycle or two and monitor it's performance, it may have tripped simply due to poor air flow from a large load etc. and therefore nothing is actually wrong...human error )
You may run the dryer momentarily without the rear panel in place provided nothing electrical has been disconnected, don't attempt an entire cycle, just witness the heater functioning, but it isn't recommended for much longer than a minute or two.
Thank you for choosing FixYa and please let me know what you find out or if you indeed require further assistance. Good luck.
Regards,
Macmarkus :)
Posted on Mar 30, 2011
Power comes on. timer says 41 min but when I hit the start button nothing happens?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Dryers
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Machine wont start. lights come on but nothing happens when I hit start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 14, 2010 | LG WM2277H Stainless Steel Front Load...
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Jun 14, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
172 people viewed this question
Top Dryers Experts
