Question about Panasonic EY7542LN2L 14.4 Volt Li-ion Multi Drill & Driver Kit with Light
My Panasonic EY7540LN2S 14.4V Lithium Ion Impact Driver stoped working after drive some long deck lags. I have changed batteries and it still won't run. Is there a reset on the drive? The batteries work fine in my drill.
  • dalesch1 Nov 23, 2009
    how makes matco 14.4 drill?
  • David Ford
    David Ford May 11, 2010
    there is no reset for the tool, how old is it, less than a year I would take it back for warranty repair. It is possible that you burnt up a motor or switch. Did you notice a burning smell coming from it. I would hope that is just a loose connection but check on the warranty first and let me know.
4 Suggested Answers
  • 903 Answers
SOURCE: Included lithium ion battery pack
Yes. Both cameras will only accept the Panasonic CGR-B/202A1B lithium ion battery pack. This special battery pack gives up to 100 minutes of use or 200 shots (based on the Fine mode, one shot with flash every 30 seconds).
Posted on Sep 01, 2005
  • 903 Answers
SOURCE: Lithium ion battery pack
damneddle
  • 1607 Answers
SOURCE: Panasonic DMC-TZ3: one day it's
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Posted on Sep 03, 2011
Torque adjustment collar very difficult to turn
try spraying some lube like WD-40 in the chuck as it is faceing up and let it set overnight it may got some moisture in it . hope this helps.
Jan 17, 2016 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
Wondering if anyone knows whats wrong with my drill...when i press the trigger the drill works sometimes and not others
Open the tool and control the purple and brown colored wire where the slide contacts are fitted on the carbonbrush holder or the switch itself.
Do allways the Battery slide connector contacts control
Remove the two sliding contacts loose and squeeze the contacts slide a bit and then connect again.
If unsuccessful buy a new switch as well as battery connectors are checked.
Feb 16, 2015 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
Can you fix a lithium battery?
The Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 us the BL1830 battery, there are several types for it, 1.5Ah, 3.0Ah, 4.0 Ah. Maybe 5.0Ah battery for it will be available. And, the inside of the BL1830 uses the 18650 battery cell. If you have a good knowledge and skill about electronic, you can buy some 18650 cell to do it yourself. If not, I suggest you to buy a brand new one.
You can buy some original battery for replacement battery for Makita BTD140 Battery
Jun 09, 2014 | Makita 18V LXT Lithium - Ion Cordless...
Dewalt dcf885 will not lock the bits in
It could be the little spring at the back of the chuck sleve is broken ot one of the locking balls is missing.
Apr 01, 2013 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
How do you remove the brushes from a bosch 18v lithum ion impactor?
On the back of the drill head there are two black caps, one on each side. If you romove the caps the brushes should come out easily.
Jan 14, 2013 | Bosch 18v Cordless Lithium-ion Impact...
Recently bought the new li-ion set...both batteries will not charge; charger display says the're broken; after 5 mos??? Bought new battery and it works fine
Also bought the new ion kit 3.0 didn't have it for a full month battiers gave me a problem. I bought one and didn't use it for a full week and did the same thing!!
Apr 11, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Panasonic EY7542LN2L 14.4 Volt Li-ion Multi Drill & Driver Kit with Light Logo
126 people viewed this question
Top Panasonic Drills Experts
Craig Butler
Craig Butler
Joseph A Howard
Level 1 Expert
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
