Question about Frigidaire FAC125P1A Window Air Conditioner
Fan works but not blowing cold air
Fan runs but air is not coldworked great last year when i installed it this year it did not work ac is only 1 year old?
    Guru:
  • 587 Answers
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
Posted on Jul 28, 2009
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Air conditioner not blowing cold air intermittently
you need a ac charge or the heater control valve is bad also check the compressor
May 30, 2012 | 2001 Ford Taurus
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
My AC worked great until last year and then after a power steering hose leak was discovered, the ac until stopped blowing cold air. I took it and paid 75.00 to have it recharged with coolant and it worked...
My air conditioner started blowing hot air last summer. I put coolant in it and didn't run it until the beginning of summer this year (2011). All of a sudden it started working again. Sometimes it blows hot but if I keep it running full blast the coolness comes back. I don't know why this happened.
Jun 26, 2011 | 2004 Kia Optima
I charged my ac last summer, worked great. This summer the 2 vents on the passenger side work great, very cold. The 2 vents on the drivers side blow air but not cold, just like the ac is not on?
One of your Actuators inside the dash that control the A/C Heat doors/ Baffles that open or close, to either give you hot or cold air has failed. Find and replace the failed Actuator and it should work fine.
Jun 24, 2010 | 2007 Hyundai Tiburon
91 geo prizm, the air conditioning works great until I turn the key off to park. While the car is still hot the fan will not turn on again until the car cools off. Then everything works great. Do I have...
When the engine is not running the belt is not turning the ac compressor which will not blow cold air unless ac pump is running so engine has to be running
Jul 28, 2009 | 1991 Geo Prizm
Blower motor problems/ac problems
List of possibilities :
blower motor
resistors
switch(On/OFF)
May 18, 2009 | 2006 Chevrolet Trailblazer
Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Oct 24, 2008 | 2002 Chevrolet Malibu
Nissan 2000 ac hot when idle
the a/c condenser has a fan in front ( there is actually 2 fans if you sit on the car it will be fan on right side ) if this fan does not
come on immediately when you are parked and engine in idle
there is a problem with power to it, or motor failure. If you drive it
on the highway and a/c operates fine that's because air is circulating though condenser (thats what the fan is supposed to do at idle or slow traffic)
Aug 17, 2008 | 2000 Nissan Maxima
Refrigeration AC not blowing cold air
If you can hear the A/C compressor start and run then your system has lost it's charge of refrigerant. If the compressor does not start and run it could be a control problem.
May 17, 2008 | Heating & Cooling
Heating & Cooling Logo
707 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
