Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Cleaning It is very difficult to get the cook top on our dual fuel range clean.  Any suggestions?  I have tried every type of cleaner that I can think of including Windex.
  • meesch Jul 17, 2008
    Burned in food that won't come off used toucher solutions then dish detergent and still nothing. How to get ahtt burned in food off the cook top
  • Conlet Aug 07, 2008
    I have the same cooktop cleaning problem. Any new solutions? Have used multiple cleaning methods, but it still looks dirty.
The firstly the top is like a beautiful shiny black car. It dazzles the eye when clean, but shows every little mess and evaporation spot when it is not. The worse problem is grease. Both on the top and on what you wash and dry it with.
At the end of each day, I use a solution of dish washing detergent and hot water to clean the top. I let the solution sit on the top for several minutes, then rinse it off with a clean rag and hot water. Then I do it again. I use a paper towel to dry the top. At first, you think you are leaving streaks, but these are small evaporation trails. Just keep on drying and the steaks disappear.
Posted on Dec 03, 2007
Electrolux dual fuel oven will not heat after self clean
The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Sep 02, 2012 | Electrolux EW30DS65GS Dual Fuel (Electric...
Cleaning the stove top.
Have you tried oven cleaner? Use the fumless type, otherwise yo will be overcome by the fumes. Clean the grill just like you would an outdoor BBQ, wire brush, the coat it with a light oil to prevent rusting.
Mar 31, 2010 | Thermador PD364GLBSS Dual Fuel (Electric...
How/what can be used to clean range ''glass top'' can those green spunges be used/
Oven cleaner, use EASY-OFF Fume Free Oven Cleaner, it is the best
for cooked stains.
You should not use anything but a soft cloth, and if you use the cleaner
you won't need something abrasive.
Once you put tiny scratches into the glass, it will be more difficult to clean.
After you clean it with oven cleaner, rinse it with a warm wash cloth a few times, to make sure no cleaner is left behind, and read the directions.
Feb 11, 2010 | Amana ARDS802 Electric Kitchen Range
How to clean pot racks
I would use one of the "Easy Off" products. Smelly but effective, spray on wait wipe off...
Feb 05, 2010 | Rangemaster Classic 110 (Dual Fuel) Dual...
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
Scratches in my flat top Maytag electric range
report the problem as "thermal cracking" and it will be rplaced by whirlpool/maytag,
these things are hard to scratch, cleaning with a FLAT edge razor scraper is the norm, there are dozens of white cream type cleaners that work well with a scotchbrite and elbow grease.
Sep 04, 2009 | LG LRE30755 Electric Kitchen Range
Burners on top will not light with the pilot lights
To Clean:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
Suggestions for cleaning the genn air stove top JDR8895aas
I have no solution but I have a Jenn-air stove, white with dual fuel and the oven door is badly stained on the top, probably from the vapors when self-cleaning. I have tried many things and they won't touch it. can someone help me out
Dec 14, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniters won't stop poppong
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. back.
Sep 11, 2006 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
118 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
