Question about Dishwashers
Dishwasher won't power up; have checked fuse; no lights coming on, on front panel
    Brigadier General:
  • 4,088 Answers
Check the house electrical panel for tripped breaker or blown fuse. Check power wiring from washer to wall outlet. Is it a cord that is plugged into a socket, or is it direct wired? If it is a socket, make sure a lamp will light if plugged into the same socket.
Posted on Jul 16, 2009
Control panel won work power
yes the have power cord. see this steps and fix it.
God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Control Electronic
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00
Jul 30, 2013 | Jenn-Air 24 in. JDB1100AWS Built-in...
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
After the last time I ran the dishwasher there is standing water in the bottom of it and now the dishwasher won't come on.
Hello, Thank You for using FixYa. I will be helping you today.It sounds like the thermal fuse failed.Open the door remove the screws around the top and flip the control panel open.There is a white fuse with two wires coming from it check it for continuity or jump the two wires together to see if it powers back up. If it does replace the fuse with part #8193762 install the whole kit just follow the directions that come with it.And remember tu turn the power off before checking and installing the fuse.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Whirlpool 24 in. DU1100XTPS Built-in...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
No power after detergent dispenser replacement
check the terminal block. thats where the power goes to the machine.could be a short ot burnt wires.
Mar 06, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
2. Door switch
3. Timer
4. Selector switch
Jul 13, 2009 | Maytag MDB7100AWB Dishwasher
No power
check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Feb 20, 2008 | KitchenAid KUDR01TJ Dishwasher
Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Jan 25, 2008 | Dishwashers
Dishwashers Logo
234 people viewed this question
Top Dishwashers Experts
