Question about Kenmore Elite Oasis 27052 Top Load Washer
Had ld code come up
Unplugged washer after not being able to get it to finish draining or turn off.Tried 3 second button then 3 second release but didn"t help since the ld code is not on anymore. washer keeps beeping though.
  • Kenmore Master
  • 3,361 Answers
Clean out your drain pump.
Posted on Jul 16, 2009
My washer keeps saying ''Ld'' It will not finish the cycle and drain. I Have tried turning it off and even unplugged it for 30 seconds. I dont know what to do!
"ld" is a service code meaning long drainage time
the most likely problem is some lint build up in pump or in the sump restricting water flow into the drain pump
Jul 18, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
My washer has a LD in the minute screen how do i get this off
LD is an error code relating to poor drainage. Check the drain hose and/or pipe for a clog. It's also possible that debris could have worked itself into the drain pump, causing a delay in drainage. Fixing your drainage problem will fix the LD error code.
Jun 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washer beeps, stops, and says LD.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error code "LD" displays, what do I do next?
an LD code indicates a long drain was detected by the control.check for a kink in the drain hose. the most common reason for this code is something caught in the pump. many times a piece of clothing(small sock,shoe lace or string from a sweatshirt etc..) gets stuck and restricts the water flow to the drain...the pump can be removed by tipping the washer forward approx 45 degrees(use something to prop the washer up so it doesnt fall all the way to the floor)then remove the back panel. the pump will be gray &have 2 hoses. calypsos used 2 styles of pump . one was integrated into the pump motor and the other was attached to the pump motor with 2 springclips.remove the clamps on the hoses and see if you can see whats caught inside..if the foreign object is wrapped up in the pump too tightly you will have to replace the pump..if you have to replace the pump and it comes as part of a new motor.,the front panel will have to come off to unplug the pump motor and plug in the new one. there is a space at the top of the front panel where it meets the lid, use a putty knife to release 2 clips so you can lift the lid up. you will see several screws along the top.remove them and the front panel will come off . you wil be able to see where the pumpmotor plugs in. . you will have to work in front and behind the washer. always unplug the washer before doing any work on your appliance. hope this helps get you back up and running...
Mar 25, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Ld code appears intermittantly
ld is a long drain time...you may have something in he drain or a bad inpeller in the drain pump...it is taking too long to drain out
Sep 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Ld code on any cycle
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis washer displays code Ld and wont fully drain
LD means long drain. Check to see if there is something clogging your drain hose. If not remove the drain pump from the bottom of the washer tub and clean it out. Also clean the recirculating pump. That should fix it. if not replace the drain pump.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis elite he
Have you tried leaving the washer unplugged for at least 30 minutes? The manufacturer recommends, first unplugging the appliance for this duration to reset the control board. In some cases this will correct momentary glitches. If this does not resolve your problem, you will need to inspect your drain pump. The "ld" error code is a Long Drain problem which is usually an indication of a clog in the drain pump or drain line, or a failed drain pump. This model washer has two pumps, I believe. One is a recirc pump, the other is the drain pump. The drain pump is below the wash tub on the RIGHT hand side (as viewed from the front of the washer). The way you access the pump is by tilting the washer backwards and working from underneath, or by removing the back panel of the washer. In order to safely tilt the washer, however, you will need to drain the wash tub. The easiest way to accomplish this without bailing is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. You will need to empty ALL residual water in order to remove the drain lines to inspect the pump. If you do not, be prepared to mop up a lot of water. Your washer has one of the largest wash tubs available.
There is also a tech sheet inside your washer with all the error codes and recommended troubleshooting advice. You can access the tech sheet by locating the release tabs along the front of the washer where the top cabinet meets the front of the washer. About 2 inches in from each side you will find a tab in the seam. Use a putty knife and push straight in while lifting up to release. NOTE: This may require some muscle to do. Once you have the top free, hold on to the washer lid BEFORE you lift up the top or the lid will fly open. The tech sheet should be attached between the front washer case and wash tub.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 15, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error code LD
I had this problem also. Ld means that it is taking too long for the tub to drain, usually something is clogged. Try taking a shop vac and sucking out the drain hose that goes into the wall drain. This should at least get you where the tub will finish the cycle you have going. I tried this and it worked for about 2 loads then "Ld" again. Finally removed the drain pump from the washer and let it empty completely. So far this has worked.
Jun 10, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
247 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
