Question about Air Tools & Compressors
Need to identify my Craftsman rooding coil nailer.
I need some parts for my craftsman roofing coil nail gun! I would guess it is 6-8 years old. It is dark gray and has Craftsman cast in raised letters on the side of the aluminum housing. Unfortunately the cheesey decal that has the modem number has worn off! I can email a pic. I can not find or order any parts with out the model #! The guy at the sears store could not help me. I know that Sears did not make this gun. Do you know who did?
    Sergeant:
    Champion:
  • 226 Answers
Chrck the devilbiss or porter cable web sites your answer probly lies there.hope this helps
Posted on Jul 29, 2009
I need a piston stop for a craftsman finish nailer part number4573.00 sears states they are not being made anymore do other nail guns use the same part
I am not familiar with nail guns but if there is a place to put a piston stop, can you use a piece of rope instead? I have used rope to stop the piston on chainsaws I have fixed where my piston stop tools wouldn't work
Jan 14, 2013 | Craftsman Garden
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
I have a craftsman roof nailer with plastic cover for nails broken where can i get one to fit
Best place for replacement parts is the address below.
Ez to order from and usually only takes 10 to 14 days to get the parts. Click on Hitachi logo then select coil nailers, then your model number. For local parts, look in the yellow page directory for fasteners. Fastener companies that sell nails and other supplies to contractors also have parts for Hitachi nailers. Check with several. Some will even repair the nailer for you if you buy nails from them.
Good luck.
WWW. toolpartsdirect.com
Sep 01, 2011 | Hitachi NV45AB2 78Inch to 134Inch Roofing...
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
I have a craftsman framing nail gun model number 351-18320 question how I reload it just got it on craiglist
Hi, W/D here.
On the side of the slide that holds the nails will be a tab. If the gun is empty, it will be close to the base of the slide, near the head of the gum. Grasp the tab, and pull it all the way back until it locks in place. Load your nails. Now, near where the tab that you pulled back is locked in place, you will see a (usually) silver button. Pull back slightly on the first tab, then push the button, releasing the lock. Let the slide push the nails into place, and you're ready to go. Place 2 drops of oil daily in the nail gun where the air line connects, then hook up the air line. Fire away!
Here is a link to an exploded diagram of your nail gun. Double click the diagram to enlarge it. On the right side of the page is the link to a free download manual. Enjoy!
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Nailer-Parts/Model-351183200/0247/0732000?searchedModel=351-18320&blt=
Best regards, --W/D--
Please feel free to rate this carefully hand-crafted solution, made especially for you. Thanks.
Feb 18, 2011 | Craftsman Nailer Kit, Palm Air Driver
N12 Bostitch comp nailer, need a few inner parts. Where can they be located? An inside rubber piece fell apart.
I have seen these parts available on ebay. They are using parts from old Unicatch roofing nailer and Max cn55 coil nailer. I have an old craftsman lathe and cut parts from other nailers to fit. This is hit and miss and does not work as well as max parts. You can be creative or just buy parts from ebay. Good luck
Jan 12, 2011 | Stanley Bostitch N12 Coil Nailer...
Shoots two nails at a time, gun jams
I found the solution to the double shooting happens when the retainer ring on the feeder paw inside half of the coil nail holder. Part #92 (962112-6) retainer ring R-22. I found the clips broken in two of my guns. Now they work great.
Oct 18, 2010 | Makita Roofing Coil Nailer AN451
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
