Question about ASUS Eee PC 2G Surf Notebook
I HAVE NEW ASUS 1005HA ON STARTUP IS SAYS WINDOES COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPT: wINDOWSSYSTEM32CONFIGSYSTEM. IT THEN ADVISES YOU CAN ATTEMPT TO REPAIR THSI FILE BY STARTING WINDOWS SETUP USING THE ORIGINAL CD-ROM. BUT IT WILL DO NOTHING FROM THSI SCREEN.
  • 5,568 Answers
This shouldn't be your problem; if the unit is new, go back to the source from which it came and let them deal with it. Any new machine should start without that kind of problem. Since it is missing a critical file, you may not be able to start it in the so-called 'Safe mode.'
Posted on Jul 16, 2009
Windows could not start because the following file is missing or corrupt:WINDOWSSYSTEM32CONFIGSYSTEM
restart in safe mode, if you can, and attempt a recovery. If this does not help use the repair facility from your windows disk
Jun 05, 2015 | ASUS Eee Computers & Internet
I get the message Windows could not start because the following file is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM it tells me to use the set up CD=ROM I attached an external drive and inserted the...
Enter your Windows OS installation CD into your ASUS laptop's CD-ROM, then restart your computer.
When your computer restarts, instead of booting up normally you will now see a Windows "Welcome" screen. Press "Enter" to continue. At the next screen, press "F8" to accept the Windows licensing agreement.
From here, i believe you can continue the process to reload or repair the operating system on your system.
Take care.
Jul 01, 2010 | ASUS Eee 4G Notebook
I have a black screen that has come up that says Windows cannot start because following file is corrupt or missing: windowssystem32configsystem then says I can attempt to repair this file by starting...
If a Repair doesn't work, then your system is too corrupt to repair, you need to install a new copy of Windows.
You won't lose your files, but you'll have to reinstall all your old programs.
Oct 22, 2009 | ASUS Eee 4G Notebook
I have a eee asus laptop. I cannot startup the window at all. The pc show this message; "Windows could not start because the following file is missing or corrupt C:windowssystem32configsystem " how can i...
you have to fix error on harddisk.
If you have winrecovery disk you can boot your computer with winxp recovery disk then boot computer with recovery disk then type in recovery console prompt "chkdsk /r" then pres "y"
then it fix error on harddisk.
Jul 13, 2009 | ASUS Eee 4G Notebook
Computer does not boot
you have to installed a new Windows xp but when he ask the repair and new installation the go for the repair you got the old files as it is
Apr 15, 2009 | Sony VAIO (PCWA-A200)
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
  6. Type exit to quit Recovery Console. Your computer will restart.
Source:http://support.microsoft.com/kb/307545
Dec 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Dell dem 3000 will not turn on
Reinstall the missing or corrupted file
May 25, 2008 | Dell Dimension 3000 PC Desktop
ASUS Eee PC 2G Surf Notebook Logo
401 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
