Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Error msg "sc552,Functional problem" on a Ricoh Afficio 1013F?
Have switched machine off and then as recommended but the problem remains?
Would greatly appreciate any help?
with kind regards
Mike
    Problem Solver:
  • 6 Answers
Works best for everyone
Do you have that can help me to wonder if I need urgent canon ir6055i service manual?
Posted on Jul 03, 2012
You either have a defective thermostat (thermistor) in your fuser, or a defective power supply. The error can only be reset by a tech in service mode after the problem is fixed
Posted on Jul 17, 2009
Afficio 1013 has error 550 problem
SC Code 550 - Standby temperature error 1
Symptom: Fusing temperature failed to
drop to expected level within a
given time (15 seconds, 15
minutes, or 25 minutes,
depending on mode) after
entering standby or low-power
mode.
Possible Cause:
• TRIAC short
• Fan not running
May 05, 2011 | Ricoh Aficio 1013F Copier
When we turn on the power we are getting an error message "Functional problem within the Copier. Please call service and report the service code SC552. Ricoh Copier Model MP5001
Solution Reset (machine was not working for 2 - 3 month):
C button (yellow) + on keyboard: 107 + C-button (orange + large) long press
Then, go to the menu
scroll
Mode 5 enter
here below 810: SC Reset
Unfortunately, there is no OK
keyboard: 0 or 1 (probably 1) choosed and press #
it displays a confirmation message: run as service - etc.
Switch off the machine
Error: reset
(on some devices without a reset command: open flap + off)
Jan 29, 2011 | Ricoh Computers & Internet
I have a Nashua sc550 Aficio 1013. Its displaying error SC550. message displayed is "Functional problems, turn off main power switch then on again. If error reoccur, call service" Best regards
Your question is somewhat confusing as to the model. There is no Nashua SC550 as that seems to be the service code you have an issue with. There is a model 1013F but there is no SC550 code for that machine. That being said I will tell you what an SC550 code means on most all Ricoh, Gestetner,Nashuatec machines. The SC550 means your fuser oil/cleaning web life is over. The solution for this is to replace the web and then reset the counter which requires entry into the service mode. Both of these are going to require a service technician to complete.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
We have a code SC552 functional problem with copier what does this mean
if the machine is a plack and white ricoh then the new error code is for the thermistors in the fuser they are not sending the correct temp readings check the fuser for toner build up on the surfaces of the thermistors and check the thermo fuses to see if they are blown....GOOD LUCK aa>>
Jul 30, 2009 | Lanier Office Equipment & Supplies
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Am having ricoh 1013 photocopier, and its giving an error message that "functional error,switch off mainpower and on"!
Low fusing temperature. Either the thermistor is bad or power supply board (unlikely). Service code can only be reset in service mode by a technician after problem is fixed
Mar 24, 2009 | Ricoh Aficio 1013F Copier
Functional problem sc552
I take it this is for a Ricoh?
SC552 is a pressure roller warm up error. It didn't detect the right temperature when it was turned on.
Turn the copier off for 30 seconds and then turn it back on again. If the error message returns, a technician should look at the fuser section to see whats causing the problem.
Aug 01, 2008 | Office Equipment & Supplies
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
819 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
