From what I can tell the EUR7627Z60 was originally shipped with the following Panasonic products: TH-37PX50U, TH-37PX50U, TH-42PD50, TH-42PD50U, TH-42PX50, TH-42PX50U, TH-42PX50UA, TH50PX50, TH50PX50U, TH-42PD50, TH-42PD50U
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Well on the Tv itself the vol up and vol down and the channel up and down will help you do this there may even be a menu key which is a nice feature but if not try pushing both the up and down vol or the up and down channel buttons at the same time. if not that try pushing different combinations you get it don't let that electronic win....lol
Must check tv carefully for tv images burn in problems,plasma tv have that problems alot.This tv have major issues are power shutdown alot and power supply will not sustance and flashes it power light indcation.Have to unplug awhile like an hour replug back to get tv to work again.If u have chance to used it like 5 hour a day like for a week have warrenty for a week for a return it and get 95% of ur money back.Used it for a week about 5 hrs every day no power shutdown and no power LED light indication flashes i whould buy it.
Hi, It could be that you have not enough power ,120v AC is what you need. If that is OK. Check for fuse that could be blown. Blinking 4 times indicates power board.
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Hi dennisreno,
You should be able to set the tv back to factory default settings from the menu.
I will see if I can find the user manual and give exact directions.
Let me know if you find the reset.
Lone99star
