MY POWER LIGHT KEEPS BLINKING ON AND OFF BUT MONITOR WILL NOT TURN ON..WILL NOT EVEN GO IN POWER SAVE MODE
    Brigadier General:
  • 4,088 Answers
Sounds like there is a power supply problem inside the monitor. Is the signal cable from the computer securely installed? It may be time for that new LCD monitor that you were looking at!
Posted on Jul 16, 2009
4 Suggested Answers
SOURCE: my LCD monitor is going into power saving mode
nothing to do with your back light.
PLEASE try another VGA cable
I say get a new vga cable and your troubles will be over,had the same problem with a dell lcd and a lg lcd new cable worked on both ! I know, how does a cable fail , who knows ? must of been a bad batch or something silly went on !
Posted on Oct 30, 2008
Matampong
  • 153 Answers
The monitor doesn't receive the signal from the PC. It is either the PC not booting up or the VGA coard is faulty. Change the VGA coard. or try reseting the VGA cord.
Posted on Nov 25, 2008
pgmadhav
  • 145 Answers
SOURCE: powersaving mode
I think your signal Cable is not connected properly.please check. Is your computer booting. Can you see HDD acivity LED blinking in your CPU?
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Posted on Jul 27, 2009
My pc was taken apart so I could move. When I hooked it back up the monitor comes on for a couple seconds and says that my pc is in analog power saving mode. The power light on the tower just blinks c
It might be in a corrupted hybernation mode.
Try turning the computer off by pushing the power button for 10 seconds and then do not choose resume but the other option.
Nov 08, 2013 | HP Pavilion Computers & Internet
CAN'T GET THE MONITOR OUT OF POWER SAVING MODE
If you have a blinking power light and no display even when you first power up the unit then its not in power saving mode. The blinking power light indicates a failure of the filter capacitors on the power supply board. This is a very common problem with LCD monitors after a few years of service. The power supply can be repaired by just replacing the defective filter capacitors. Here is a picture of the power supply board with the bad caps circled in yellow and below that is a link to a full repair guide showing how to open the unit and what to replace including a full parts list.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
I hope this helps you out,
BuddyMc
Feb 11, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
How do I get the Monitor out of analog power save mode
More than likely the unit is not in power save mode, When in power save and you turn the unit off and back on you will get a picture. If its still will not display a picture or your power light is blinking then you have a shorted power supply board. We have a step by step repair guide posted on our web site at: www.ccl-la.com Look it over and check your monitor, this is the most common cause of no power, picture or just a blinking power light. If you have any questions just ask, We have full technical support available.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 11, 2010 | LG L196WTQ Monitor
My dell e173fp monitor has quit working. The power light continually blinks when power is applied, even without having to turn it on. An identical substitute monitor works fine on the computer system. ...
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Sep 10, 2009 | Dell E173FP 17" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Monitor keeps going to power save mode
the settings should be the same as your notebook power saver settings or you will have to check extended monitor in your graphics card properties in control panel.
Sep 26, 2007 | Toshiba (K000006610) for Satellite P25...
Computers & Internet Logo
956 people viewed this question
David Payne
David Payne
