The paper im using is canon red label superior.
You should be able to select the paper type you use before starting the print. The printer should optimise the print to match the paper you have specified. If the paper is not for photos, it shouldn't matter too much unless the ink is taking too long to dry. It is more likely that your print heads are skimming the paper or something is brushing the image while the ink is still wet.
