Question about Gateway M280E
When I make a selection using the mouse I used to be able to tap on the mouse pad for this Gateway Tablet PC, now I have to use the right-click selection.
  • mowens_svsu Jul 17, 2009
    I need to find out where to locate the "tapping zone" in the control panel settings. I downloaded the information but the section is grayed out. Troubleshooting the issue says it is working properly.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 94 Answers
If you go to the Gateway computers support site there may be updated drivers or software for your tablet pc that allows tweaking the mouse pad adjustments (with more refinement possible than was on your tablet originally).
It is also possible that the pad is experiencing wear / mechanical problems.
Posted on Jul 17, 2009
How to get my tablet to start rotating again. It is set to auto rotate but it won't stop working.
This varies by operating system which is why it is a good idea to post the brand, model, and operating system with a query.
For a Samsung Galaxy 10.1:
Type apps is the upper right corner. Then tap Settings from the all tab. Then in the left menu, tap screen. Then, tap auto rotate
For the Inspiron Dell 2-in-1 with Windows 10:
Go to Control Panel> Display>Change Display Settings and then make sure that the "Allow the screen to auto-rotate" is selected. Or try the following: Place the tablet into Pad/Tablet mode.
Click the Start Start menu and select Settings. Click System.
Click Display. Scroll down and toggle Lock rotation of this display to ON.
Or this might help:
Click the Start Start menu and select Settings. Scroll down and toggle Lock rotation of this display to OFF.
Nov 26, 2017 | Tablets & eReaders
Cursor jumps to corner of screen, is erratic
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Dec 29, 2013 | HP EliteBook 2730p Tablet PC
Am having an HP laptop.Now i am having a problem with my mouse touch pad..the touch pad is working,but i am not able tpo clink on anyfile using mousepad.The coursers are moving when i scroll on th mouse...
Your laptop needs to visit a laptop service/repair centre.
However you can purchase and make use of a USB mouse; it'd serve.
If you own one, use it instead.
Oct 13, 2017 | HP Pavilion TX2000Z Tablet PC
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
Shut off touchpad
Most pc's use a program named symnaptics touch pad. Go to the control panel, select the mouse tab then mouse properties and device settings (select disable). Here you can disable the touch pad. I would recommend you have a usb mouse up and running prior to doing this procedure (saves tons of headache).
Aug 07, 2009 | Panasonic Toughbook-19 Tablet PC
When I click the mouse pointer it doesn't work I have no choice but to use the right mouse buttons to make selections. How do I fix this issue?
Usually this problem can be easily solved by accessing and changing your mouse settings. On your PC desktop, click "start", then click "control panel", then click "mouse", then on the "buttons" tab you'll see an option that says, "button configuration". That button needs to be adjusted according to which side of the mouse you'd like the pointer to work from. Once you set the side you'd like, make sure you click, "OK" to seal the deal!
Hope this helps.
Sincerely, CBR2009
Jul 16, 2009 | Gateway M280E
Where can i download sofware of gateway
For your tablet to function again, you'll need the WACOM tablet driver which is NOT provided by Gateway, since they do not manufacture the tablet themselves.
You'll need the following drivers from the GATEWAY site to fix your button issue:
9524572.exe - Gateway M275 Button driver, version 5.01.2600.2156
and from the WACOM site you'll need the Tablet PC driver.
-Go to www.Wacom.com
-Select your location and language on the right
-On the next page, choose downloads from the top navigation bar
-In Step 1 scroll down and pick Tablet PC
-In Step 2 choose your operating system
-Follow the download instructions provided on the site from there
Jan 17, 2009 | Gateway M275 Tablet PC
How to use the pen
Using the pen is quite simple.
You extract it from its storage space and use it as a mouse, left clicking it as you would a mouse.
By pressing the tip of the pen on an area on desktop or on an application window and maintaining the pressure for a short while, you activate the context menus (the equivalent of a right click.)
On the Windows task bar (for Windows XP) there is a small icon near the start button that shows a pen pointing outside: that is the input panel. Click the icon with a mouse or your pen, and an input area opens. In that area you write with the pen (writing Pad) or enter letters and symbols one at a time (Character Pad) or use a virtual keyboard.
Under the red X that closes the input panel there is a small gear. C;ick the gear with the pen or a mouse to configure the settings.
Your pen may have an eraser at the rear end and/OR on the side. It is used to erase characters or whole sentences.
To actually record (write) what you enter with the pen you must have a text-editing application open and running.
Whenever you approach the pen to the screen near a text-area (search area of IE or other compatible applications) a small icon appears to be clicked to enter text. This happens is you select UNDOCK in the input panel configuration.
This should get you started with the pen. Try these steps, and if you have any other questions post them as comments to this thread and it will be my pleasure to answer them.
Nov 30, 2008 | Toshiba Portege 3505 Tablet PC
Mouse pad problem
Please Install Driver software for touchpad. If the same problem continues let me know.
Mar 15, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Mouse Pad and Right and Left Buttons
Great job, I myself prefer to use a extra mouse rather then the built in one, if you chose to do this it wont work right away but if you give it a moment to recognize the mouse it will then be functionable.
Jan 04, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Gateway M280E Logo
127 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
