Question about HP OfficeJet 6210 All-In-One InkJet Printer
Bought a new color cartridge, but my printer is still not printing in color. All I get are some light blue colors with lines going across them. Any other color does not print at all--except for the black.
Turn off grey scale !
Posted on Jul 17, 2009
After every line of black text there is a light blue line.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
My Epson color printer 880, prints erratic and very small print in a light black and sometimes blue color
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
Dec 17, 2009 | Epson Stylus 880 InkJet Color Printer
The printer is only printing in two colors and only in lines going across the page. not a full print
Make sure that the ink you have, is Epson Ink.
I bought a compatible, supposely ink, and when I put it in, Colors did not come out the same. Lines and words, did not print out properly.
So I threw the ink cartridges, and bought original, Epson Ink, and Ooh-LA-LA, Printed out just fine.
Go Figure.
Good Luck
Nov 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Can't print in color
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
I have installed two new ink cartridges #80 and #70. When I try to print I get black lines across the page and some blue printing as well as the symbol of a flag shape with colored squares that are...
the cartrudge is not got detected in the printer .as click the properties of the printer go to solution center and then click the options tab and then get the cartridge detected in the printer.and then it will work.
Dec 10, 2008 | Lexmark Computers & Internet
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
